Search found 396 matches
- Sun Apr 04, 2021 9:05 pm
- Forum: Projects
- Topic: Past project
Re: Past project
I've been finding this really interesting to follow along
- Fri Mar 26, 2021 1:08 pm
- Forum: Projects
Re: Past project
I feel like having a go for a test.
- Sat Mar 13, 2021 6:55 am
- Forum: Projects
Re: Past project
That's really nice
- Sat Feb 06, 2021 12:26 pm
- Forum: Projects
- Topic: Lantern in Green Oak
Re: Lantern in Green Oak
Nice job
- Thu Feb 04, 2021 12:09 pm
- Forum: Power Tools and Machinery
- Topic: Compact sliding table saw choices.
Re: Compact sliding table saw choices.
It's a great saw, arm stays ban on accurate when you need to take it off for ripping long sheets or timber. It's a really reliable good joinery saw. I sold.it for a bigger slider because I got fed up taking the arm off as I did a lot of sheets and also used the slider to straight edge timber. If you...
- Thu Feb 04, 2021 10:27 am
The little SCM is a great saw, 1600 slider. Nova 300s I think, wish I never sold mine.
https://jmjwood.co.uk/products/scm-si-3 ... panelsaw-1
What is it you are making?
- Wed Feb 03, 2021 12:10 pm
- Topic: Planer thicknesser choices
Re: Planer thicknesser choices
Thats a bit rich for that machine. I have an SCM minimax fs410 with the tersa block. Its OK but the lifting the tables and moving the thicknesser is a pita. I'm on the lookout for a seperate thicknesser to get round this. The machine has pretty long beds that make life so much easier. The green sedg...
- Wed Feb 03, 2021 12:07 pm
- Forum: Woodworking
- Topic: Staircase upgrade ..
Re: Staircase upgrade
I would pre drill them for a hefty dowel then cut them, them put the dowel in for the joint. Round spindles would be simpler.
- Wed Feb 03, 2021 10:21 am
But a continuous rail has no newels...so how do you stop it falling off the top of the spindles ..OK...I'm being a dumb clucx, I know :oops: The are fitted to the treads first then into the handrail. They can be dowelled or drilled into the handrail. Match the end of spindle diameter with a forster...
- Wed Feb 03, 2021 9:16 am
Mine old one had the 2 knife block, you just need to take is low but the finish is good. If I remember rightly it had rollers as well on the thicknessing bed. The tables are pretty short and extensions are a must. David - make up your own extensions, the aigner ones ate great, I have a couple; but t...
- Mon Jan 18, 2021 3:23 pm
- Topic: MDF Faced Blockboard
Re: MDF Faced Blockboard
Ita made by SWL in Germany, I'm over here and its a new one to me. Not sure who supplies it in the UK, Lathams Lawcris perhaps?
- Mon Jan 18, 2021 12:21 pm
Are any of you guys using or have used the MDF faced blockboard?
I'm thinking about it for kitchen carcasses and door panels.
- Sat Oct 31, 2020 11:42 am
- Topic: Door Panel
Re: Door Panel
I'm in the middle of Germany.
This is a bit out of my comfort zone and I have been overthinking it and avoiding it for far far too long. Plus they do some things differently here and it keeps throwing me, I find it hard to follow the logic sometimes.
- Thu Oct 29, 2020 9:24 pm
- Topic: Door Panel
Re: Door Panel
Thanks Mark, I'm going to break the panels into three parts, I'm really worried about cracking. I have been over thinking this for far too long. The difference in temperature ranges in the summer to the winter here can be quite extreme. In summer it has the lunch and afternoon sun, which can be utte...
- Thu Oct 29, 2020 8:53 pm
- Topic: Door Panel
Door Panel
I have fielded panel to make for a front door and can't make my mind up which way to orientate it. Its going to be an insulated panel - sapele each side of some celotex, door is a crazy 88mm thick. The panel is a single unit and quite wide I can't make my mind up which way to joint it, with the grai...
- Sun Oct 25, 2020 9:18 pm
- Forum: Finishing
- Topic: What to use for filling around panels, joints, etc?
Re: What to use for filling around panels, joints, etc?
I hate the stuff as well, until I had a lesson from my Uncle who is an old decorator, now I can just about bear it.
- Sat Oct 24, 2020 7:16 am
- Forum: Finishing
Have you tried a bead of caulk round the edge and a quick wipe over with a damp sponge to fill the edge. I don't think brummer or the morells filler will too easy round the panel.
- Wed Sep 16, 2020 9:04 pm
- Topic: Woodworking With Children
Re: Woodworking With Children
Have a look at the Paul Sellers common woodworking. I have been trying to get my kids onto it as it#s a good introduction to tool basics and has some easy projects involved. I would also make them draw something at least once so they can lay out off the drawing and see how it relates to the actual o...
- Wed Sep 16, 2020 9:02 pm
- Topic: Timber pricing/size - rule of thumb?
Re: Timber pricing/size - rule of thumb?
I'd be surprised if you got a price for hardwood boards. You would normally get a per cubic foot or cubic meter price. Boards often vary greatly in width over the length and you will be paying for some unusable timber. It's best to go down and pick out the boards you want, the amounts can rack up qu...
- Wed Sep 02, 2020 7:47 am
- Topic: Sandlefors door furniture. Looking for mechanism...
Re: Sandlefors door furniture. Looking for mechanism...
A standard bathroom mortice lock should fit it
- Wed Sep 02, 2020 7:15 am
- Topic: Floating shelf bracket for books?
Re: Floating shelf bracket for books?
Ate they going into an alcove? I have build and installed ladder frames into the alcoves then clad them with veneered and solid front. It can be a pain to fit, scribing and sometimes templates but they look good when done. Price wise I always found shelves are always mote expensive than you would th...
- Mon Aug 31, 2020 6:38 pm
I never had much success with them. They tend to droop over time and trying to get them to sit nice on old walls is a nightmare. Another option is a bit of threaded bar resin anchored into the wall.
- Fri Aug 28, 2020 6:52 am
- Forum: Hand Tools
- Topic: Plane sold without blades
Re: Plane sold without blades
https://www.oldtools.co.uk/products/rec ... ade-no-778
you can also get them from faithfull
I really wouldn't be bothered about the provenance of the blade,it is there to do a job and more than likely it will only be doing it part time. Keep it sharp, keep working.
- Wed Aug 26, 2020 6:05 pm
- Topic: Veneer press weight
Veneer press weight
I'm looking at making and offer on an old manual triple screw veneer press. Have you any idea how much it might weigh?
- Tue Aug 25, 2020 7:47 am
- Topic: Gable Apex Joint?
Re: Gable Apex Joint?
I'm finding it hard to figure out which bit to be shocked at first!
- Fri Jul 10, 2020 7:21 am
- Topic: Aquamac cutter
Re: Aquamac cutter
They still point at airplanes where I live, and the old people in the village still talk about when the road came. No joke. The cities are very different, I lived in Hamburg for a year 20 odd years and that was amazing, but the countryside here has its own ways. When we moved over I was very very sh...
- Thu Jul 09, 2020 11:17 am
Re: Aquamac cutter
No its been Germany for the last 6 years. Been renovating an old farmhouse amongst other projects that keep me busy.
- Wed Jul 08, 2020 9:18 pm
Re: Aquamac cutter
Non Le Bosche land
- Wed Jul 08, 2020 8:43 pm
Re: Aquamac cutter
It' needs to be the router cutter, Wealden don't have any in stock for a while.
- Wed Jul 08, 2020 10:58 am
Aquamac cutter
Has anyone got an Aquamac 21 cutter they would be willing to part with?
Beg borrow or steal
Beg borrow or steal
- Mon Jun 22, 2020 2:42 pm
- Topic: 4 sider extraction
Re: 4 sider extraction
Hi David
I have got the normal sitax and it wants 20m/s or 3600 cubic meters an hour. I think yours will do a bit wider so probably somewhere around the 4000
Hope it helps
Hope it helps
- Wed Jun 10, 2020 7:54 am
- Topic: Ok how many of you guys would..............
Re: Ok how many of you guys would..............
That is another option I had considered.
- Tue Jun 09, 2020 7:56 am
Funny you should be asking this. I'm over in Germany and the whole door system is completely different here and they are reliant on the domino or large dowels as the standard fixing system. I'm literally about to start the front door for our house and it has been giving me the most enormous headache...
- Tue May 12, 2020 7:49 pm
- Topic: Re boring spindle blocks
Re: Re boring spindle blocks
I did that and it worked really well. Well until I changed back to a 30mm. In the interviening time I had sold up my machines in the UK and had the heads in storage. Got hold of an big old moulder over here and put the head on. Started it up, the machine started making a terrible noise and decided t...
- Fri Apr 17, 2020 9:04 am
- Topic: Festool TS75 trouble
My old TS75 is really starting to struggle. I have mainly been using it for rough sizing timber before I get it to the table saw. Over here I am buying everything now from the sawmill in big packs or boules and the boards are a bit of a handful. To be fair I need to get another saw for ripping thick...
- Wed Apr 01, 2020 8:33 pm
- Forum: Projects
- Topic: Recent Staircase
Re: Recent Staircase
Fantastic job, I would love to have a go at doing a handrail like that. I've only done a few stairs but have always enjoyed them.
- Thu Mar 26, 2020 12:31 pm
- Forum: Finishing
- Topic: Dark stain
Re: Dark stain
What about Morrells stain?
- Wed Feb 12, 2020 12:58 pm
- Topic: Making a 120mm dia hole....
Re: Making a 120mm dia hole....
120mm forster bits are available. You could use one with an extension, I'd probably use my core drill to turn it.
The bits are about 80 euros for a cheapy over here.
- Fri Jan 10, 2020 7:19 am
- Topic: Corian Glue for fixing together of-cuts ?
Re: Corian Glue for fixing together of-cuts ?
I don't think so Bob. It is to do with the guarantee with the finished product. Hehe fabrication has to be done by an approved trained fabricator.
There are some chipboard core worktops with a thin layer of solid surface available. They were pretty expensive and I have never used them.
- Wed Jan 08, 2020 7:11 pm
Hi Mark
CDUK in Leeds are the UK Corian distributors.
Any questions drop me a line. I did my fabrication course years ago.
