Running 40mm waste through joists.
lynx
Very Regular Poster
Postby lynx » Thu May 09, 2013 11:45 am
Next question.
Converting ensuite to a wetroom. Most of the trays available put the waste one joist over so I need
to run the waste pipe through the joist. Can I drill a 45mm hole into the joists, if so, can what heights
etc?
LyNx
Re: Running 40mm waste through joists.
Postby woodsmith » Thu May 09, 2013 1:35 pm
It all depends on the joists and where you need to drill, but roughly;
you can not drill any holes in the middle third of the length; so if the joist is 3m long you can only drill within 1M of each end.
you can not drill any holes within 50mm of another hole or notch
the hole must be at least 50mm away from any edge
if it complies with that then you can drill a hole up to 1/3 of the depth of the joist
lynx
Very Regular Poster
Postby lynx » Thu May 09, 2013 1:38 pm
Thank you Keith. From the information above it looks like a can work this in. Great news
LyNx
