Re-landscaping Garden
Postby Roger-M » Wed Oct 19, 2016 11:10 pm
Haven't posted much woody stuff this year as I have been busy doing other things. Having completed our kitchen extension and refit, the garden was a scene of devastation and needed re-landscaping. This was the scene through our bifold doors.
First job is to get in a digger and a skilled driver to level the ground and dig foundation trenches for the retaining walls.
Then set out some levelling pegs in trenches to mark the top of the concrete fill.
Concrete was bought in by pump.
The walls are initially built from concrete block, and then faced with local Yennadon Stone. We needed 8 tons of block, 19 tons of stone, 8 tons of paving slabs, 15 tons of sand, 3 tons of cement, and 5 tons of gravel. So that's 58 tons of materials to be barrowed down from the road to where it's needed. My wife matched me barrow load for barrow load!
The side retaining wall was left as block for reasons of economy. Facing stone is £135 per ton. The rule of thumb is that the thickness of the base of the wall should be between 1/4 and 1/3rd the height of the finished wall, so here it starts at 3 blocks thick, then thins to 2 blocks and a single block for the final course.
The "stealth bomber" cutout is a template for the steps, with holes to mark where the inset lights will go.
Once the lower walls are faced with small walling stone, it's time to build a dry stone wall at the upper level using medium walling stone.
And the finished article.
.... and hopefully you'll agree that the view from the kitchen is somewhat improved.
Re: Re-landscaping Garden
Postby jake » Wed Oct 19, 2016 11:29 pm
Nicely done, it looks like it has been there forever which says something good about .
Postby woodsmith » Thu Oct 20, 2016 8:11 am
Fabulous job. You're a very very lucky man!
Postby tusses » Thu Oct 20, 2016 8:56 pm
I don't usually post much on these non woody posts .. but that looks really nice Rog ! .. you must be pleased !
Postby promhandicam » Thu Oct 20, 2016 11:27 pm
Well done to both of you. Other than the help with the digger and laying the foundations did you and your wife do all the rest. If so then I think you deserve a holiday!
Postby Tomyjoiner » Fri Oct 21, 2016 7:12 pm
Job well done!
Postby Roger-M » Fri Oct 21, 2016 8:09 pm
Thanks guys.
promhandicam wrote:Well done to both of you. Other than the help with the digger and laying the foundations did you and your wife do all the rest. If so then I think you deserve a holiday!
That's pretty much the size of it Steve. The digger driver was brilliant at getting the levels right - did a far better job than I could have done, and whilst he did the digging I drove the power barrow to remove the spoil. Foundations were pumped concrete as it would have taken forever to mix it myself, and we would have struggled to shift 6 tons of readymix and lay it accurately in the trenches before it set. I subbed out laying the paving, as time was pressing and again it would have taken me for ever to lay 50 sq m. However, I laid every last block (200 - about 8 tons) and every piece of stone (19 tons), and built the steps, and just got a local apprentice in to render the side wall.
