Scale doors in sketchup
kevob
Postby kevob » Sat Dec 17, 2016 7:33 am
Is there a way to scale doors in sketchup without the style and rail width size changing?
Rogerdodge
Re: Scale doors in sketchup
Postby Rogerdodge » Sat Dec 17, 2016 1:26 pm
I think there is , yes. Make Stiles, Rails and Panels Components ; to change the length of either or both , click edit component , scale tool , (use measure tool to mark the desired length) You might want to hide the panels whilst you do this. Once S and R s are the right lengths and back together, unhide the panels and scale them up to fit.
Rog
Oakfield
Postby Oakfield » Sat Dec 17, 2016 11:34 pm
Or, if you haven't built it properly using components, use the select tool and draw a box down through the centre and select half the door - then use the move tool to move the stile across to where you want it. - do the same for the height.
Postby ftacarpentry » Sun Jun 11, 2017 9:05 pm
I've just been querying the same thing on the skethup community forum...
https://forums.sketchup.com/t/dynamic-c ... in/46175/7
It's all about dynamic components (think of it as a combination of spreadsheets, sketchup, and how you actually make the item in question). Sounds, awful, but really isn't!
I now have a library of cabinets (carcase/faceframe/doors/drawers etc) that are scaleable without changing dimensions. It saves so much time!
