Dishwasher door on a lay plinthed kitchen
Has anyone done a intergrated dishwasher on a lay on plinted kichen. have done loads on a recessed plinth but not lay on. Any pointers please
Re: Dishwasher door on a lay plinthed kitchen
I use a 750mm door on a 135mm plinth with a total height of 870mm, so an overlap of 15mm. Sometimes depending on model the DW has to be wound down slightly and a 18mm packer put above to ensure overhang does not hit DW on opening. if it's a short run i'll just dry fix that bit of plinth, if it's a long run I'll fix the dishwasher bit on mag catches.
