Scm sintex setup
murdoch
Scm sintex setup
Post by murdoch » Thu Jan 05, 2017 12:45 pm
I know quite a few people on here this machine and wondered if anyone can tell me how to raise or lower the first bottom head so it planes perfectly flush with the bottom outfeed table?
http://Www.murdochjoinery.co.uk" onclick="window.open(this.href);return false;
Re: Scm sintex setup
Post by senior » Thu Jan 05, 2017 2:35 pm
remove the ventilated gaurd below it, loosen off the allen screw attached to a rod.
Make sure the bed is raised to full height about 110mm, in line and behind the first outfeed knurled feed wheel is a plate with 3 grub screws, the back one is turned to raise or lower the spindle.
Never done it as mine has been spot on from day one but I have the manual.
THIS IS FOR THE ORANGE AND WHITE MACHINES, post 2003.
murdoch
Post by murdoch » Thu Jan 05, 2017 3:46 pm
Thanks so much for that, just adjusted and it's now perfect. Help much appreciated
