wheelie bin storage where to get the wood
lawzoo
Postby lawzoo » Thu Aug 24, 2017 6:24 pm
hi to all looking to build wheelie bin storage but the wood frame looks like it has been routed out to take the slats can you buy the wood already routed what do I ask for out or do I need to do it my self
thanks
Re: wheelie bin storage where to get the wood
Postby woodsmith » Thu Aug 24, 2017 10:50 pm
It looks like it's just laths layed on the slats and nailed or screwed together. If you were to rout slots you would be exposing the less treated inner part of the timber which would encourage rot to set in.
lawzoo
Postby lawzoo » Fri Aug 25, 2017 11:54 am
hi thanks for the reply but it is def a u channel with the slats in it I have other pics
Andys Woodshed
Postby Andys Woodshed » Sat Aug 26, 2017 8:27 pm
It is probably routed out and then pressured treated
Expensive process for small quantities
You could enquire at your local merchant about providing the finished profile pressure treated. I know Carvers would provide such a service
vince
Postby vince » Sat Aug 26, 2017 9:26 pm
It appears to be made from Decking boards, not a great design in my opinion, there being a rail below the gates, and obviously a full bin would need to be lifted over it, not an easy task for the elderly i would think.
Postby Roger-M » Mon Aug 28, 2017 4:51 pm
If I didn't have access to machinery, I'd follow Woodsmith's approach above. i.e. batten either side and screwed together, sandwiching the slats in between, and then maybe nail a third piece on to cover the exposed edges. Just adopt a common sense approach - this isn't fine furniture making. :D
