Is 25mm too thick for concealed hinges?
Oakfield
Postby Oakfield » Mon Oct 09, 2017 8:56 pm
I am building a kitchen at the moment.
I normally finish my doors and face frame at 22mm thick and use normal Blum hinges for inset doors.
On this particular job I have finished the doors and face frame at 25mm and I'm just wondering if I have made a mistake!
I know you can get Blum hinges for inset doors up to 32mm thick but didn't know if they have to have extra large gaps or any other issues I may not of thought about.
I will also have 2 blind corners, so ideally need hinges for thick doors that will work in that situation.
I have designed the fridge unit so the door can be hung on overlay hinges.
I will also need a couple of doors to be top hung.
Does anyone thick I will have problems finding hinges to fit thick doors in the situations?
Thanks,
Mark.
furynaturre
Re: Is 25mm too thick for concealed hinges?
Postby furynaturre » Mon Oct 09, 2017 9:11 pm
Hi Mark,
Some of the Grass Tiomos will work for thicker doors
https://www.hafele.co.uk/en/product/con ... 0&PDP=true
I find they work well.
Not sure about the blind corner ones but i'm sure with some jiggling with plate heights and positions they will work.
https://www.hafele.co.uk/en/product/con ... 2&PDP=true
Postby Tomyjoiner » Tue Oct 10, 2017 9:47 pm
+ 1 for Grass from hafele, used them a few times on thicker doors.
Theirs plenty that will do up to 28 often just the backplate changes.
Oakfield
Postby Oakfield » Wed Oct 11, 2017 11:07 am
Thanks for the info guys.
I will not machine my door Components any thinner then!
Postby promhandicam » Thu Oct 12, 2017 10:57 pm
I've also used the tiomos hinges on thicker doors, and they are now my standard concealed hinge.
