Convex Bench Slats
Plecc
Convex Bench Slats
Postby Plecc » Wed Oct 11, 2017 9:19 am
Hi all,
I would like to try and make a set of oak bench slats with a convex top face. E.g. One continuous ark across the top face from one side to the other.
I appreciate that forms like this are typically produced on a fancy profileing machine, but is there a way I could produce this at home with electric hand tools?
I'm struggling to come up with a suitable jig myself.
Thanks,
Plecc
Re: Convex Bench Slats
Postby woodsmith » Thu Oct 12, 2017 3:55 pm
You could make a jig to do this with a router, but, especially if you don't have a lot to do, you could just use a plane to shape them.
Plecc
Postby Plecc » Fri Oct 13, 2017 5:26 pm
Thanks woodsmith,
I was hoping to be able to reproduce them a bit quicker and more consistently than i could achieve with a plane.
do you know of any examples of a router / electric plane jig i could take a look at to get some ideas from?
i have tried searching myself but im not very clued up with woodworking terminology, so i tend to keep finding quite obscure stuff.
Postby woodsmith » Sat Oct 14, 2017 8:17 am
For jig read home made jig. Just a couple of pieces of MDF cut to the required shape and made into a box would do the job, but you could use the same MDF with a plane and use it as a guide. If you have a power planer take off the bulk of the waste and then a few passes with a hand plane would have it done. I have a spindle moulder, which is the quick way of making something like this, but if I only had a few to do I'd use a plane as it's quicker than setting up the machine. Alternatively if you have access to a bandsaw you could remove most of the waste with that, but you would still need to hand plane a final finish.
Postby Meccarroll » Sun Oct 15, 2017 7:33 am
What tools do you have at your disposal? What about laminating thin pieces to make the convex shape? Not much needed for that operation.
Plecc
Postby Plecc » Sun Oct 15, 2017 1:21 pm
I think I have managed to find a jig that would be suitable.
Its a router jig used for forming the shallow ark on a guitar fingerboard, here is the post - http://www.anzlf.com/viewtopic.php?t=4897
I dont realy want to build one thats large enough to enclose a whole bench slat, so i would need to shape a section of the slat maybe one meter at a time and then slide the slat through the jig, reset position and shape the next meter and so on.
what do you think?
Hi Maccarroll,
Hand tools
* Small, Med and Large standard hand planes
* A few rasps and files
* Various hand saws
* Some small chisels
Power Hand Tools
* Router
* Plane
* A few sanders
* Circular Saw
* Jig saw
* Sawsall
Bench Tools
* Small linisher
* Pillar Drill
* Thicknesser
I hope to have a planer/jointer within the month, just struggling to find a budget one thats not a total piece or c***.
think i may go for an old one on e-bay that i can tidy up and customise a bit.
Users browsing this forum: No registered users and 10 guests
