Joint suggestion
danielcio
Joint suggestion
Post by danielcio » Sat Dec 28, 2019 11:16 pm
Using which joint method would you guys recommend for making such a connection ? Bevel to straight on a kind a thin elements.
Re: Joint suggestion
Post by davidpidge » Tue Dec 31, 2019 7:52 am
Biscuits but clamping would be tricky.
Post by Meccarroll » Tue Dec 31, 2019 9:37 am
Think I would go for biscuits too but it's going to be tricky without a good jig for lining up the bevel ones.
Post by Meccarroll » Tue Dec 31, 2019 9:51 am
For assembly I sometimes super glue components in two or three places so they hold in place while I assemble an item. I still use other wood glue as well on the joint, it is just that the super glue holds the component in place while the wood glue setts so I don't need clamps so much. I think you could part glue and fit some of the lower section of the unit so it is held in place before assembly of the entire unit but it's going to be slightly tricky nevertheless. It will be a good learning curve.
Post by davidpidge » Tue Dec 31, 2019 11:28 pm
This is when the Zeta p2 pays for itself!
Post by Meccarroll » Wed Jan 01, 2020 7:07 am
Looks very interesting. Too costly for a one off but could pay for itself if the project was large enough.
https://www.youtube.com/watch?v=alaQfU6mRLY/
Good heads up David! I would have never have known it existed if you had not posted about it here.
danielcio
Post by danielcio » Wed Jan 01, 2020 11:32 am
Biscuits will be the way to go ! Thanks guys for the suggestions. I will make some test joints with the cheap biscuit jointer I have,if it will not work I will upgrade it to makita/dewalt one.
will1983
Post by will1983 » Mon Jan 06, 2020 3:03 pm
Danielcio, I have the Makita biscuit jointer and it's really good. Bit noisy but works great and very accurate.
