Resurfacing a coffee table
cheddarman
Post by cheddarman » Sat Feb 08, 2020 9:21 pm
Not sure resurfacing is the right term but, I've got a 30yo Cherry coffee table, 4' X 20" and it's showing its years with scratches and marks all over.
What would be the best procedure to restore it to its former glory? Fine sanding g and re polishing??
Re: Resurfacing a coffee table
Post by thatsnotafestool » Sun Feb 09, 2020 8:18 am
Yes provided it's a solid top and not veneered. If the latter then you can still sand etc but take care not to sand through the veneer.
When you say polishing, do you mean French polishing 'cos that is a skill. There's other stuff out there you can use.
cheddarman
Post by cheddarman » Sun Feb 09, 2020 9:00 am
Restoring the shine, that's where I'm not sure. Varnish would probably look a bit too shiny so I'm thinking multi layers of wax?
Post by thatsnotafestool » Sun Feb 09, 2020 9:23 am
I like Chestnut Microcrystalline wax. Seems to repel water quite well. If you want a more tougher surface then Rustins Plastic Coating is god. Don't let the name put you off.
https://www.amazon.co.uk/Rustins-PCGL10 ... B002HMXR18
cheddarman
Post by cheddarman » Sun Feb 09, 2020 1:34 pm
many thanks, most helpful!!
Post by Meccarroll » Sun Feb 09, 2020 6:18 pm
You can always use a varnish coat to seal the surface then use wire wool soaked in wax to cut the shine off the varnish then buff to finish.
cheddarman
Post by cheddarman » Sun Feb 09, 2020 10:13 pm
Sounds good Meccarrol, I presume a very thin varnish.
Can one not just use wax, loads of coats over time?
Post by 9fingers » Mon Feb 10, 2020 8:06 am
2parts pu varnish 1 part white spirit
I use three coats de-nibbing between coats and wax applied with 0000 wire wool.
Post by woodsmith » Mon Feb 10, 2020 9:20 am
A wax, on its own, finish soon marks. A diluted and applied thinly varnish as 9fingers suggests is good or you could use Osmo Polyx, again applied thinly in several coats.
Post by Meccarroll » Mon Feb 10, 2020 10:11 am
Yes you can use wax on it's own and some wax formulas are better than others at protecting the surface of wood from stains etc. Using a varnish first helps to seal the surface of the wood and if done correctly as Bob states won't detract from the waxed finish look once completed.
cheddarman
Post by cheddarman » Tue Feb 11, 2020 5:02 pm
OK, couple of thin varnish first, rubbed down and the get the elbow grease going with the wax!
For initial rubbing down I presume fine emery/sand paper - like very fine and very lightly, just enough to remove marks, or better to go right back to bare wood?
I think the top is solid Cherry, not veneered.
Post by thatsnotafestool » Tue Feb 11, 2020 5:13 pm
Back to bare wood as you don't know how the existing finish will react to whatever you're putting on. It's why ROS sanders were invented.
Post by Meccarroll » Wed Feb 12, 2020 4:37 am
If you use the right sandpaper for each stage of sanding it will make life a lot easier. Before you do any sanding clean the surface with white spirit first to remove any wax or other residue because this will clog the sandpaper and prevent you from making much progress. I have not had any problem using PU varnish on previously coated wood surfaces myself but as Roger has said you may run into trouble with none compatible finishes so either test an area or sand right back to wood. I have put a link to a quick guide about sandpaper, it will give you an idea of what paper to use. Cheap sandpapers are a waste of time and not very effective at removing waste material because they degrade easily, the grit comes away from the backing paper making them none effective.
Have a read of this link: https://www.thesprucecrafts.com/choose- ... er-3536493
cheddarman
Post by cheddarman » Wed Feb 12, 2020 9:33 am
Many thanks Meccarroll, most helpful! Fell armed with everything I need now so will have a go.
I'll keep you guys posted...................
