. . .for the glazed doors I glue them up without any panel, when the glue is set use one of the cutters and a bearing to machine off the the back inside of the stile to form a rebate, square up the corners and then bead the glass in. A bit of silicone around the glass will give it extra strength.
If I go for the maximum thickness rail / stile of 23mm, then I will have about a 6mm rebate behind the glass to pin on a glazing bead. Is this sufficient? If so would you use just an ordinary bead like this:
or something a bit more substantial like this:
.jpg)
Thanks in advance,
