and no, I don't use a hard-point saw for my tenons. davyowen wrote:A tablesaw is not a suitable tool for cutting tenons, .
davyowen wrote:Personally, I would always recommend using the bandsaw for cutting the cheeks and then a safer alternative for the shoulders would be to cut them by hand, with a mitre saw with depth stop or a radial arm saw.
davyowen wrote:I personally use the spindle moulder, but before I had that I always cut the cheeks on the bandsaw and the shoulders by hand.
A mitre saw with a depth stop only works if it's the type that has the trenching facility. My DW mitre saw has a depth stop but still cuts at an angle and so is NBG for this.
mattty wrote:A mitre saw with a depth stop only works if it's the type that has the trenching facility. My DW mitre saw has a depth stop but still cuts at an angle and so is NBG for this.
Roger the trick with the mitre saw is to put/use a false fence. This sends the workpiece far enough away and produces a square parallel cut. Unless you mean the saw head travel isn't travelling parallel to the bed in which case i cant help
jfc wrote:Some people cut the top of the riving knife so it doesnt need to be removed
thatsnotafestool wrote: There is the overhead in replacing the blade with a nice cross-cut blade
jake wrote:thatsnotafestool wrote: There is the overhead in replacing the blade with a nice cross-cut blade
It isn't a cross-cut though - it's a rip (at an unusual angle)- isn't it?
roger&out wrote:I don't like the look of those tenoning jigs & I'm a bit surprised that they can be legally sold. .....?
Mr Ed wrote:A spindle is on the list, but then so are many other things! Its something that will have to wait until I have the ground floor part of my workshop cleared and in use as I cannot have any more cast iron on the first floor. In the meantime I think I will get a specific cutter for the router table and then at least I can use basically the same method that would be employed with the spindle, without the weight and expense.
Ed
mattty wrote:Mr Ed wrote:A spindle is on the list, but then so are many other things! Its something that will have to wait until I have the ground floor part of my workshop cleared and in use as I cannot have any more cast iron on the first floor. In the meantime I think I will get a specific cutter for the router table and then at least I can use basically the same method that would be employed with the spindle, without the weight and expense.
Ed
Dominos aren't heavy...
Ed
Mr Ed wrote: Does anyone have experience of the tenoning cutter that CMT make as a kind of poor mans alternative to a spindle
jfc wrote:Its crap and unsafe . Take yer jig and do one
hunggaur wrote:jfc wrote:Its crap and unsafe . Take yer jig and do one
having jsut join the forum it is nice to meet such warm and open people as yourself who are open to discussion and other points of view (i think not)
