unsprung hinges
JHWBigley
unsprung hinges
Postby JHWBigley » Sun Oct 17, 2010 4:45 pm
Im hoping to use a touch latch on some lay on doors.
http://www.hafele.co.uk/Hafele35a1/imag ... 05-195.pdf
They say they are to be only used with unsprung hinges. so which hinges?
I hate the hafele website. :x
thanks
JH
It's not about the tools, but I still keep buying more. . . .
http://john-henrybigleyfurniture.blogspot.com/
Re: unsprung hinges
Postby jonnyd » Sun Oct 17, 2010 4:53 pm
These will work 0 crank for full overlay 15mm for an inset door
http://www.hafele.co.uk/Hafele35a1/Temp ... prung&tab=
jon
Dont use the middle latch on that page there pants
Re: unsprung hinges
Postby promhandicam » Sun Oct 17, 2010 6:19 pm
What size doors and how many? If the doors aren't too big, then I'd be happy to let you have some of these catches and hinges for the cost of the postage. You would need to order some of the locking part - the round bit that goes into the door. Let me know if you are interested.
jasonb
Re: unsprung hinges
Postby jasonb » Sun Oct 17, 2010 6:27 pm
I've used these catches on a couple af cabinets recently, they drill into the carcase and look a lot neater than the ones in your link.
http://www.ironmongerydirect.co.uk/Prod ... ism/789818
ID will also have the unsprung blum hinges or if you already have some sprung ones it s not too hard to remove they nylon spring
Jason
JHWBigley
Re: unsprung hinges
Postby JHWBigley » Sun Oct 17, 2010 6:49 pm
Thanks for pointing in the right direction Jon. I've used those middle latches before on loft hatches, proper pants.
They look smart Jason! how many did you use on a door?
promhandicam wrote:What size doors and how many? If the doors aren't too big, then I'd be happy to let you have some of these catches and hinges for the cost of the postage. You would need to order some of the locking part - the round bit that goes into the door. Let me know if you are interested.
I've only got one door at 350x510mm. That's really generous Steve, I'll happily take up your offer thanks mate.
JH
Re: unsprung hinges
Postby woodsmith » Sun Oct 17, 2010 7:19 pm
Jason they look smart, thanks for the link, I've got a handle free cabinet to make too.
jasonb
Re: unsprung hinges
Postby jasonb » Sun Oct 17, 2010 8:29 pm
I just used one per door think they were about 800 high and definatly 500mm wide, Mirrors on the front too. Not the best pic but there are 3 doors above the basin, cabinet set flush into boxing. You can either push to open or just give the edge of the door a gentil pull and they will open.
