If a chippy can't get a job in Austria.........
Postby modernist » Fri Apr 19, 2013 3:19 pm
Just thought I'd share my 50 Euro a night hotel for which I get a 3 room suite and breakfast. Premier Inn take note. It was built new in 1990.
Typical Austrian wood everywhere and AFAICT not CNC'd apart from some of the carvings, and even then not certain. Most finish is straight from the plane. It's not my normal style but these guys know what they are doing and it makes a change from MFC boxes.
Dining room
Bar area
Interesting mould detail they can consider stolen
More bar
These are either deliberately uneven or done by hand
Terrible shot but this serpentine panel is definitely straight from the plane as is the surrounding framework - no sanding.
Looks hand carved to me
Brilliant art nouveau/deco'ish lighting
More ceiling areas
Wall panelling
Now for the interesting stuff
First a really nice handmade iron and brass staircase with marble treads
And finally the piece de resistance, a double opener, arch top, tilt and turn, with full Euro rebates. The gear appeared to have been bent around the curve - awesome. The joint at the pointy corner is a twin bridle with 3 steps on the outer rebates plus scribed glazing rebate on the inside and (very unusually) mitred top and bottom. Not one to be tackled after a night on the pedigree!
As I said not my normal fodder, apart from the stairs and window, but good to see.
Re: If a chippy can't get a job in Austria.........
Postby paulchapman » Fri Apr 19, 2013 3:27 pm
Very nice. That window is interesting.
Postby mark270981 » Fri Apr 19, 2013 4:20 pm
very nice indeed.....................On paper that would like overkill, but the reality it works rather quite well.
They did they not think you were a bit weird taking so many pictures of the place?
Postby modernist » Fri Apr 19, 2013 5:13 pm
mark270981 wrote:very nice indeed.....................On paper that would like overkill, but the reality it works rather quite well.
I'm not bothered, anyway most people are pleased I am interested in their place. I always keep an eye out for good stuff. We are so inward looking in the UK and we need to see what others do.
As an example here are a few snaps from Innsbruck today
I still can't find the gear to do this with the right setback
Just look at that for a door handle!!
There is so much to see and it's good stuff.
Postby thatsnotafestool » Fri Apr 19, 2013 5:36 pm
Wow...some nice stuff there, Brian. The door handle is my favourite.
Postby jonnyd » Fri Apr 19, 2013 9:16 pm
Good stuff Brian
aquila
Postby aquila » Sat Apr 20, 2013 1:11 pm
Some good looking stuff. Which hotel is it?
Postby modernist » Sat Apr 20, 2013 1:26 pm
aquila wrote:Some good looking stuff. Which hotel is it?
The Tyrolis in Zirl.
tyrolis.cc/englisch.htm
aquila
Postby aquila » Sat Apr 20, 2013 2:01 pm
Postby tusses » Sat Apr 20, 2013 4:31 pm
Thanks for sharing Brian
I love that kind of stuff :)
Postby promhandicam » Sat Apr 20, 2013 4:53 pm
Very interesting Brian. Are the semicircular windows triple glazed with the leaded light sandwiched between the outer panes?
