Table Saw (£400 budget)
mushroomgodmat
Postby mushroomgodmat » Mon Sep 17, 2018 2:14 pm
Hi All,
Im looking for some advice - Id like to buy a simple table saw for some basic cabinet/shelving making. I have a budget of £400
Any advice would be appreciated.
Re: Table Saw (£400 budget)
Postby promhandicam » Mon Sep 17, 2018 11:21 pm
welcome. personally i would look at a plunge saw / guide rail if you are mainly going to be using man made boards.
plutomoon
Postby plutomoon » Sun Dec 23, 2018 5:02 pm
I was just saying in another thread I have an Evolution Fury 5 and couldn't be happier. They were more expensive when I bought mine in 2015, now you can get it for as little as £150.
https://www.amazon.co.uk/Evolution-FURY5-S-Multi-Purpose-Table-230V/dp/B01DP3V368
Postby Meccarroll » Sun Dec 23, 2018 11:12 pm
promhandicam wrote:welcome. personally i would look at a plunge saw / guide rail if you are mainly going to be using man made boards.
Hi Steve and Merry Christmas to you and all on the forum. Now to the question: I don't actually own a plunge saw myself as most of my current work is site carpentry (structural) and only dip in and out of panel work occasionally. I have used them when supplied by main contractors or firms I have worked for and find them useful but I would not personally recommend one over a table saw for general work. I just wondered why you advocate buying one over a table saw? I use my hand circular saw with a multi blade and it does a decent job on MFC one side and will cut nicely with no chipping if the sheet material has a protective plastic film on. Is it something you use both on site and in the workshop and do you find it quick to set up?
Postby promhandicam » Mon Dec 24, 2018 10:22 pm
In answer to your question Mark, I've got a felder panel saw in the workshop and wouldn't be without it. However the op has a budget of £400 for a saw for making cabinets and shelving and so I assumed they would be cutting down sheet material. Therefore I personally think that a track saw would be the way to go.
Postby thatsnotafestool » Wed Dec 26, 2018 3:54 pm
I'm with Steve on this one. Need a proper blade though with the right teeth for carcasses if you're using Conti type board to prevent the edges chipping away.
Also, regardless of blade, a sheet (can be seconds) of Kingspan/whatever on which to lay the board down to cut.
katellwood
Postby katellwood » Thu Dec 27, 2018 4:33 pm
just my two penneth
If you are cutting full sized sheets (8 x 4) on a £400 table saw you are going to struggle and the initial cuts will not be very accurate.
I also use a Felder with a sliding table however for the initial cuts I start with a dewalt track saw and a 2.7m track.
Its far easier to carry the saw to a full sized sheet than a full sized sheet to the saw and push it through for an accurate cut (area around the saw/workshop size comes into this as well)
Kingspan is a good idea however i use a torsion box without a top made out of rippings of 1/2" ply approx 4" deep
martin.pearson
Postby martin.pearson » Mon Jan 07, 2019 3:11 pm
I am new to this forum & not a woodworker as such, I worked as a signmaker for nearly 20 years so cutting 8 x 4 sheets was something I did on a regular basis & it is something I wouldn't consider on a table saw unless it was something that was made for that purpose. Sub £400 you can only be looking at a site saw I would have thought. I have a makita site saw & its a great bit of kit but I wouldn't use it to cut full sheet material, I have a wall panel saw for that & a range of diferent blades for different substrates.
As has been said getting an accurate cut on a site type table saw is extremely difficult, steets are always eith to floppy if thin or to heavy if thicker lol
Can't comment on a track saw as never used one :D
Rogerdodge
Postby Rogerdodge » Tue Jan 08, 2019 3:08 pm
+ 1 on the Tracksaw for me. I have the Makita , and it has been an excellent purchase for me. You can get a fitting to put on the track to give very accurate right angle cuts too.
