Dust Extract adapter
sargan
Post by sargan » Sat Mar 02, 2019 6:00 pm
Need help with a dust extract adapter.
I have a workshop dust extractor - via a cyclonic separator ... which has a flexible 50mm pipe .. and fitted onto the end a rubber adapter than allows it to fit neatly onto a 40 mm male spigot.
That means I can happily use it with several of my power tools directly or using ... using the DeWalt 60-40mm adapter that came with my bench saw.
However one item has an extract connection that I have so far not found adapter for.
This is a Record BS250 bandsaw .... it has a male spigot with an outside diameter of 60mm .... and I am having problems finding a 60 to 40 adapter.
Does anybody know of one ? .....
(Needs 60mm diam ID at one end and 40mm diam OD at other)
I could buy a piece of nylon rod and turn one down ... but be expensive
Re: Dust Extract adapter
Post by 9fingers » Sun Mar 03, 2019 9:15 am
Easily made from offcuts of upvc pipe and solvent cement plus hacksaw.
