Can’t get my planer to cut straight.
Golfer4588
Post by Golfer4588 » Thu Mar 21, 2019 11:18 am
I have a Luna w64 combination machine and am having a problem with the planer.
I realise this subject has come up quite a few times but I have tried every suggestion I could find.
I am trying to joint 3 pieces of oak for a small table top, each piece approx 1000mm x 240mm x 110mm.
No matter what I try, the cut is always concaved.
When 2 pieces are put together, there is an approx 1mm gap in the centre.
I have checked the in/outfeed tables are coplanar. I only did the straight edge test with 2 different straight edges and I’m pretty confident that things are ok.
I’ve tried many different blade heights from a few tho below outfeed table to a few tho above and everything in between. Ended up sticking with a hair higher than the outfeed table.
There is absolutely no give in the oak so I don’t think it’s a pressure issue but I’ve tried many different timbers and get the same results every time. As soon as the piece is on the outfeed table, I concentrate the pressure there.
It’s incredibly consistent because I tried covering the entire surface with pencil and making the shallowest cut I could and the knives removed all the pencil every time. The sound of the knives cutting is very consistent for the entire cut.
I have run out of things to try so any help would be very much appreciated.
I’m pretty new at this and hopefully, I’m making a schoolboy error!
Maybe a good service wouldn’t hurt? I’m based in Hollywood just South of Birmingham if anyone could suggest anyone?
Richard
Re: Can’t get my planer to cut straight.
Post by 9fingers » Thu Mar 21, 2019 10:34 pm
Your blade height sound right to me and so does your technique of pressure transfer.
I think it can only be lack of coplanarity.
Golfer4588
Post by Golfer4588 » Fri Mar 22, 2019 6:05 am
Thanks Bob,
I'll check it again.
Post by Jonathan » Fri Mar 22, 2019 7:15 am
Many manufactures send machines out ready to plane a spring joint ....
Try setting in and outfeed level with each other, then check the tops for flatness .....if this shows a very slight concave you will get a spring joint
