WADKIN MK / RM - OIL GREASE
rhrwilliams
Post by rhrwilliams » Sat May 04, 2019 8:05 am
Hi All,
I have recetly got a new Wadkin MK planer thicknesser which is the predecessor to the RM - its a big fu*ker
Can anone tell me the correct oil and grease specifications to use on it ? It has lots of grease caps on all the bearings and an oil sump in the back for the gearbox. I imght as well give it a service etc Before being Put into use.
I was going to use High Temp Grease for the bearings , and just stick super universal tractor oil in the back end ?
I can see however you can buy special Wadkin oil in grades 1/2/3/4 ?
Any help would be apprciated. I am currently setting the thing up and getting all the bits bakc together.
Richard
rhrwilliams
Re: WADKIN MK / RM - OIL GREASE
Post by rhrwilliams » Sat May 04, 2019 8:13 am
Here she is coming in the workshop.... tipping down with rain of course.
rhrwilliams
Post by rhrwilliams » Sat May 04, 2019 8:16 am
On another side note I was originally going to pick this up with a trailer and get it on with an engine hoist and or a winch - NO WAY. Its brutally heavy, the body (without planer tables / motors etc) is over a ton and its impossible to move even in the workshop. I got a HIAB to pick it up on a truck and glad I did !
Post by JonR » Sat May 04, 2019 2:42 pm
Serious bit of kit mate are you gearing up to do joinery full time at some point ?
Btw how did you get on with the waterbourne laquer ?
rhrwilliams
Post by rhrwilliams » Sun May 05, 2019 9:48 am
I would love to do it full time, but I am not sure I could ever make it work. I am still just doing my own stuff and the odd thing for others. I bought it as I have the space, machines to move it and it was cheap....and Ive always wanted one. The joke is ill probably sell my old Sedgwick for about the same I paid for the Wadkin.
THe Laquer went really well - ill post it in the project bit as its a little quiet on there at the moment.
If your ever down in East Sussex / Kent borders - pop in.
rhrwilliams
Post by rhrwilliams » Sun May 05, 2019 1:23 pm
All assembled now. What a machine !
wallace
Post by wallace » Mon May 06, 2019 2:47 am
That is a lovely original machine, I hope you keep it like that and don't paint it. I've got its brother the MJ. For lubrication I would take the bearing end cap off and see whats in their. You don't need fancy high speed stuff just a decent quality bearing grease. For the gearbox don't use anything like hypoid because the box has bronze bushings. My gearbox leaks because someone ran it with grease and it wore down the shaft going through the casing to the pulley. I cant remember what oil I got but will check
rhrwilliams
Post by rhrwilliams » Mon May 06, 2019 9:14 am
Thanks Wallace
There is a mix of different colour greases in the bearing caps - some black stuff and some yellow “standard” grease .
No I’m keeping it as- is. I like the colour - looks like an old war relic ! The only thing I’m doing to it is servicing it and trying to free up the feed speed gear knob that’s ceased .
Vann
Post by Vann » Sun Nov 24, 2019 8:16 am
...Can anone tell me the correct oil and grease specifications to use on it ? ...
I don't have an RM nor a MK, but I acquired a Wadkin PK dimension saw three years ago. When I tried to source lubricants I went to a local Mobil outlet that caters for industrial users (as well as selling petrol).
To replace Wadkin Grade L.6 grease they recommended Mobil XHP 222 grease;
to replace Wadkin Grade L.4 oil they recommended Mobil DTE Heavy-Medium.
I hope that helps.
Cheers, Vann.
Post by jfc » Mon Nov 25, 2019 5:50 pm
That is a beast !
Post by promhandicam » Wed Nov 27, 2019 10:24 pm
I bet the dog wasn't still sitting there when you turned it on @rhrwilliams! Probably still hasn't recovered 6 months on!
