Cross sled for table saw
Docjames122
Post by Docjames122 » Sun Sep 01, 2019 5:48 pm
I’m new to all of this and trying to build a cabinet for an out of the way space as a starter project.
I am trying to work out how to cut sheet plywood on a table saw as my fence only goes to 35 cm and I need a cut at 61 cm.
Happy to build a crosscut sled but the ones online are either really complicated or too small. Any ideas.
Re: Cross sled for table saw
Post by promhandicam » Sun Sep 01, 2019 9:06 pm
welcome to the forum. if you only have a small table saw then I would strongly suggest not trying to cut sheet plywood on it. either get your supplier to cut it to size - most timber yards offer this service, or if you are going to be doing a lot of work with sheet materials look at buying a plunge saw. The festool TS55 is the most well known and arguably the best, but there are cheaper alternatives. If you don't want to fork out for a plunge saw but have an ordinary circular saw then you can buy or make a guide rail for it.
Docjames122
Post by Docjames122 » Mon Sep 02, 2019 7:09 am
Steve,
Thank you. I thinkI will try this one with my circular saw for the big pieces and see how I get on.
Post by woodsmith » Mon Sep 02, 2019 9:16 am
You need a panel saw to cut 8x4 sheets safely but as Steve said it's easy enough with a track saw or circular saw. The trick is supporting the board and for that I use an 8x4, 50mm thick sheet of foam, not the foil sided stuff just insulation slab which you can get from BnQ. Set the depth of the cut to just a touch more than the thickness of the board so you only just score the foam and it will last you years.
