nickw wrote:Mr G's need for micro adjustment is also no doubt caused by his use of home made cutters. For shop bought cutters, shop bought bearings will, most of the time at least, come in the right sizes. And anyway you can always adjust your template instead.
Mike Jordan wrote:Hi
I use both a ring Fence (home made) and bearings with various size outer rings. The least expensive way of trying out a guide bearing is to sandwich a bearing between two circular pieces of 18mm ply fastened together with screws, you can then alter the outer diameter at will.
Mike Jordan.
davyowen wrote:If you don't make your own, its unlikely that a ring fence will ever be cheaper than bearings. For £360, you could buy 10x bearings and every single guide ring Wealden sell (17) from 75mm - 150mm. And its unlikely that you'd need such a variety of sizes or need more than 1 or 2 bearings. I get by with just 4 at the moment + 1 bearing.
I know that Grim thinks its an esentional piece of kit, but obviously manufacturers don't, because most machines don't come with one as standard any more, yet they all come with a straight fence
mrgrimsdale wrote:I see a ring fence as a primary piece of essential kit, just like the straight fence. You can make your own easily if you want to save a bit (mdf, ply, or sheet metal if you are into metal work). They are much more adaptable than bearings to different functions and in the long term will be a lot cheaper.
Return to Power Tools and Machinery
