woodworker wrote:4 knives gives a faster feed speed, not necessarily a better cut, the tct knives have a slight adjustment clearance in the throat, so it depends how well you can set up the 4 knives.
FWIW if your not going to be making cills all the time, why not just buy a set of profile knives.
woodworker wrote:FWIW I have both 2 & 4 and you can't tell the difference in the real world. it's the feed speed that's the real advantage here imho.
If you don't hold them against the back of the throat as you tighten up the knives you'll definitely get a misalignment as the locating pins are smaller than the holes on the knives.
I know thatcuttingsolutions wrote:the "locating pins" are supposed to be smaller than the holes. if they were the same size the pins would shatter the "fragile" carbide.
Its a standard method used on disposable knife cutterheads for more years than I care to recall.
I know thatcuttingsolutions wrote:setting the knives of this type of cutterhead is simple.....
place the knife onto the wedge.
firmly push it against the bottom of the seating across its full length whilst tightening the three grub screws.....starting with the middle one which should not be fully tightened but enough to hole all in place....
I never said you needed any setting device.cuttingsolutions wrote:you can judge it me "finger feel" ....you shouldnt need any setting devices.
As I said originally, in the real world etc etc.cuttingsolutions wrote:as to the feed speed....sorry thats not correct.
These blocks are for use in manual or powerfeed.cuttingsolutions wrote:most of these are "manual" feed operations
Sorry, but In the real world you'd be pushed to tell the difference.cuttingsolutions wrote:and I defy anyone to feed at a constant and same rate each time.....thats the work of CNC machines. as I already said........4 knives will give a better finish at the same feed speed. or allow faster feed speed for the same finish.
thatsnotafestool wrote:Z 3 V 3?
woodworker wrote:why not just buy a set of profile knives.
cuttingsolutions wrote:thatsnotafestool wrote:Z 3 V 3?
Three cutting knives (Z=3) and three spurs (V=3).
thatsnotafestool wrote: I'm not that sure what, if anything, that washer with the wee key thingy does that I normally use with the other blocks. 'Cos it won't fit with this baby.
modernist wrote:..... I would not do it with any length of cap above the spindle top.
interchippy wrote:I guess the reason you have a keyway on your spindle is that you can run it in reverse, as is the case in our M-power spindle.
thatsnotafestool wrote:modernist wrote:..... I would not do it with any length of cap above the spindle top.
Thanks for the info, Brian. Not sure what you mean by the above.
Return to Power Tools and Machinery
