promhandicam wrote:I do have a domino but don't use it to make frame and panel (shaker) style doors. I use this set of cutters from wealden which with the addition of an additional groover can be used to make doors with either 6mm or 9mm panels. I do have to make some glazed doors soon and was thinking of using dominos to assemble the frames on those but for regular doors I don't think they are really necessary. Will be interested to hear other peoples thoughts.
gazza wrote:Any particular reason for the hinge placement ?
cncpaul wrote:Same here, for the glazed doors I glue them up without any panel, when the glue is set use one of the cutters and a bearing to machine off the the back inside of the stile to form a rebate, square up the corners and then bead the glass in. A bit of silicone around the glass will give it extra strength.
modernist wrote:gazza wrote:Any particular reason for the hinge placement ?
It's Euro Man
It's Euro Man
mark270981 wrote:I am thinking of buying the carvex jigsaw tomorrow - eeeeeekkkkk is it worth it??
Return to Power Tools and Machinery
