oiling mahogany
cornishjoiner
oiling mahogany
Post by cornishjoiner » Wed May 14, 2014 9:38 pm
Hi guys,
Never used Mahogany before, i planed some pieces up sanded and added a little oil (osmo clear). It has gone all streaky, some parts really dark and other light. Is this normal and if so how, how do i get a uniform result?
Many thanks
Re: oiling mahogany
Post by thatsnotafestool » Thu May 15, 2014 2:05 pm
It sounds to me as if you've got a mix of grain direction. Some mahogany, for example, flame mahogany has the grain swirling around every which way. When I finish mahogany I use a thin wash coat of shellac first before I do anything such as staining as the wash coat will seal any end grain that is present on the surface.
Can't help re oil.
Re: oiling mahogany
Post by thatsnotafestool » Thu May 15, 2014 7:19 pm
Like I used on this
Imagehttps://flic.kr/p/nBLgzn
Re: oiling mahogany
Post by jake » Thu May 15, 2014 10:24 pm
That's a nice semi-repro piece Roger.
The lower panel isn't quite as good as fish-dinosaur, but it does look like a bit like a cropped pic of someone of indeterminate sex waiting to receive doggy-style sex. That's the imaginative bit I like most about it. It's the spine and the anus that does it. Such are the skills of tiling and book-matching.
Re: oiling mahogany
Post by thatsnotafestool » Fri May 16, 2014 5:00 am
Gosh, Jake. I am in shock and awe at your rapier sharp wit. Don't give up the day job. You are not cut out to be a comic.
Re: oiling mahogany
Post by mattty » Fri May 16, 2014 7:57 am
jake wrote:That's a nice semi-repro piece Roger.
Lol, Fish dinosaur was the best thread ever!
Re: oiling mahogany
Post by jake » Fri May 16, 2014 9:37 am
thatsnotafestool wrote:Gosh, Jake. I am in shock and awe at your rapier sharp wit. Don't give up the day job. You are not cut out to be a comic.
Awww, don't be sore.
Re: oiling mahogany
Post by jake » Fri May 16, 2014 10:13 am
Matttttty!
Serendipity for those who haven't seen it: http://woodworkuk.co.uk/forum/viewtopic ... ped#p47160" onclick="window.open(this.href);return false;
