Sadolin Ultra vs Sadolin Classic vs Sikkens Cetol Filter 7 Plus
Post by Roger-M » Thu Nov 02, 2017 9:41 am
A previous test set up in 2012 compared Osmo UV Oil and Sikkens Cetol Filter 7 Plus on Iroko, and it was not long before Sikkens showed its class. But would that be the same on other species of wood? And how would it compare with Sadolin? That's what this new test is set up to establish.
This time I've used separate test pieces for each timber and finish, and each piece of wood for each species comes from the same plank.
Column 1 is Iroko
Column 2 is English Oak
Column 3 is Sapele
Column 4 is treated softwood
Row 1 (Top) is Sadolin Ultra (Walnut). One coat of Sadolin clear base coat with 2 coats of top coat
Row 2 is Sadolin Classic (Walnut) 2 coats
Row 3 is Sikkens Cetol Filter 7 Plus (Walnut). One coat of Cetol HLS (Light Oak), with 2 coats of Cetol Filter 7 Plus (Walnut)
Row 4 is Sikkens Cetol Filter 7 Plus (Pale Oak). One coat of Cetol HLS (Light Oak), with 2 coats of Cetol Filter 7 Plus (Light Oak )
Row 5 (Bottom) is bare wood with no finish.
All finishes were applied onto dry wood with a brush in accordance with manufacturers instructions. All edges have been rounded over.
It'll be interesting to see which brand comes out on top, and also whether the more pigmented Sikkens Walnut is more durable than the Pale Oak equivalent from the same manufacturer.
The whole artistic creation will be placed upright facing south in full sun, and as before, I'll update every 6 months, or when I remember, or when asked!
Re: Sadolin Ultra vs Sadolin Classic vs Sikkens Cetol Filter 7 Plus
Post by woodsmith » Fri Nov 03, 2017 8:33 am
Brilliant, look forward to the updates. I had a glue test in the garden for many years, it became a point of discourse and division when it became less sightly!
Post by Leveller2911 » Sat Nov 04, 2017 10:21 am
Glad you posted another test set Roger, look forward to seeing how they all stand up. I often use Sikkens Cetol filter 7 and also the HLS with Filter 7 top coat.
Cheers Again Leveller.
Post by Roger-M » Sat Nov 04, 2017 10:59 am
Thanks Leveller. My guess is that Sikkens Filter 7 (Walnut) will be the winner, but I'm particularly interested to see how it fares against Sadolin Ultra. Time will tell!
davy
Post by davy » Mon Aug 06, 2018 3:30 pm
I tend to treat external woodwork as I would decking. I.e I dont want anything that peels or flakes cos it is a bugger to rub down before applying a maintenance coat.
I find that:
- Sikkens Filter 7 is good on vertical surfaces but hopeless on horizontal surfaces
- OSMO UV wax was useless at preventing the wood greying and left a blotchy appearance and then impossible to apply maintenance coats over wax.
So every couple of years I
- wash down to remove dust and bird droppings
- apply fungicide or bleach to remove black algae stains
- apply clear wood preserver - especially to joints
- apply clear or very-lightly coloured decking oil which soaks into the wood
No scrapping or sanding necessary. All quickly slapped on with a brush so takes very little time.
This procedure allows the wood to fade to a silvery grey (looks good on iroko) without black streaks
You could try this on one of your untreated panels?
Post by Roger-M » Fri Feb 08, 2019 8:29 pm
Here is an update on the Sadolin or Sikkens test pieces.
After 15 months the only ones showing visible signs of degradation are the Iroko and English Oak with Sadolin classic (Walnut). The Sadolin Classic on the Sapele and Treated Softwood is fine, as are the other finishes. I wouldn't expect much degradation after just one summer. Let's see what another one does!
Post by woodsmith » Sat Feb 09, 2019 8:28 am
Thanks for the update, much appreciated.
Post by Leveller2911 » Sun Feb 10, 2019 1:07 pm
Thanks Roger, really appreciate your efforts and keeping us updated..
Bodgejob
Post by Bodgejob » Mon Aug 05, 2019 6:14 pm
Hi all I am new here but been looking at this and the other test by Roger regarding longevity of wood finishes against weather and UV with great interest. Any update on how they are holding up? Was originally going to coat my new oak property sign with Osmo oil but after seeing how it held up overtime on the other thread all be it on a different type of wood I am niw thinking the Sikkens is probably the better way to go?
Post by Roger-M » Tue Aug 06, 2019 2:50 pm
This test has been running for 21 months now, and we're well into the second summer. As expected, mixed results so far.
The Sadolin Ultra, and both Sikkens finishes (walnut and light oak) are holding up well on all timbers. That's rows 1, 3 and 4, with row 5 being bare uncoated timber.
The Sadolin Classic (walnut) is however, already showing signs of deterioration on the iroko (column 1) and English oak (column 2), although still holding up well on the Sapele (column 3) and treated softwood (column 4). I didn't degrease any of the woods with meths before painting, so I'm wondering whether that has had any influence. This next photos shows the iroko (left) and oak (right) treated with Sadolin Classic.
Let's see what damage another summer inflicts on it.
Bodgejob
Post by Bodgejob » Tue Aug 06, 2019 4:18 pm
Thank you Roger,
Originally I was going to use Osmo 420 oil as I would have liked to show off the natural beauty of the grain but think the best course of action now will be to go down the Sikkens Light Oak route judging by the results of both tests. The wood I have to treat is currently bare European White Oak and will also be situated in a South facing position with coastal conditions, would there be any benefit of using more coats than the single coat of Cetol HLS and 2 coats of Cetol Filter 7 Plus you use as per the instructions on the tin? If so what would you say the most beneficial number of coats would be?
Post by Leveller2911 » Tue Aug 06, 2019 4:41 pm
Bodgejob wrote:Thank you Roger,
Do you mean European Oak or American white Oak?. The reason I ask is American White Oak is only moderately durable, same grade as Sapele etc so not as durable as European Oak.. American White Oak is usually used for internal Joinery rather than External.............
All the best Leveller.............
Post by Leveller2911 » Tue Aug 06, 2019 4:43 pm
Cheers for the update Roger, I'm gonna stick with Sikkens I Think..........Re meths, I wonder if it would have made any real difference, I don't really see even Iroko being very Oily these days so not sure meths would make any difference...
Post by Roger-M » Tue Aug 06, 2019 5:14 pm
That's beyond my pay grade! :lol: Given that the paint companies are in business to sell paint, I don't see them specifying fewer than the optimal number of coats. This stuff has to breathe, so I don't think extra coats at the outset would necessarily help.
As Leveller says, are you using European Oak or American White Oak? For outside use, the normal choice would be either European Oak or English Oak, with American White Oak normally being used for internal furniture.
Bodgejob
Post by Bodgejob » Tue Aug 06, 2019 6:12 pm
It is English Oak that as been kiln dried and left undercover for about a year to settle. Sorry for the confusion I was under the impression that English and European Oak was the same species and a member of the White Oak family?
telos
Post by telos » Wed Aug 07, 2019 4:41 pm
Roger, thanks for continuing with this. It really is a fantastic real world test and a great resource for anyone searching for actual evidence. I hope your photos remain available for many years to come!
Post by Roger-M » Mon Jul 20, 2020 8:42 pm
Nearly 12 months on, so time for another update.
The top row, Sadolin Ultra, is wearing well, although there are slight signs of deterioration on the English Oak (second column).
The second row, Sadolin Classic, is showing signs of deterioration on all woods.
The third row, Sikkens Filter 7 Plus (Walnut), is holding up well apart from on the English Oak (second column) where it is showing clear signs of deterioration.
The fourth row (Sikkens Filter 7 Plus (Light Oak) is also wearing well, although there are slight signs of deterioration on the Sapele (Column 3). I treated a sapele postbox at the same time with this and that is also showing signs of deterioration so I will paint it again this summer.
The bottom row is natural wood included as a "control". We are now 2 yrs and 9 months in so would expect some sort of deterioration in that time, as the test is south facing in full sun, and with a salty atmosphere as this is a coastal position.
So far the clear loser here is the Sadolin Classic (row 2). There would appear to be little to choose so far between the Sadolin Ultra and the two shades of Sikkens. Possibly the Sikkens Walnut is faring slightly less well than the Sikkens Light Oak, which was contrary to expectations, but it is still early days. Let's see what another year brings.
Post by woodsmith » Tue Jul 21, 2020 8:05 am
Thanks for the update. I’m just about to finish my 20 year old oak greenhouse which had a coat of tung oil when new and nothing since. I’m was planning to use Sikkens dark oak, now I’m wondering if I’d be better off with light oak. I thought darker finishes were more durable, we have Sikkens ebony on the house woodwork and that has been very good but Judith doesn’t want a black greenhouse. Decisions!
Post by Roger-M » Tue Jul 21, 2020 8:21 am
Keith - I expected the Sikkens Walnut to weather better than the light oak, but the reverse seems to be happening, although the difference isn't really significant at this stage. If the tung oil has lasted 20 years, is there any reason you aren't using that again?
Post by woodsmith » Tue Jul 21, 2020 8:41 am
Ha! The tung oil lasted a few months at best and then Judith decided she wanted the natural aged look so I never treated it again. The oak looks riven, which has its own charm, and looks good on the bigger timber sections, but smaller pieces like glazing beads have suffered and some parts of the roof have rotted where the glass traps moisture. Now it needs some major repairs particularly after storm damage this last winter. I’m going to take the roof off and completely refinish it inside and out, fit new aluminium opening lights and sort the roof so it no longer traps moisture. Just got to got to finish making the Adirondack chairs Judith has got me making, then it’s my next job.
telos
Post by telos » Tue Jul 21, 2020 12:23 pm
My guess would be the darker Walnut colour is getting warmer (absorbing more radiation) and therefore expanding and contracting more than the light oak colour. I think that would account for most of the performance difference in the two Sikkens rows. All four woods will have differing rates of expansion as well.
