Big old cupboard thing
Post by jonnyd » Thu Aug 07, 2014 7:58 pm
A job just finished .
Start with 50m2 of quartered European oak from capital crispin.
Joint it into large layons approx size 2.3 x 5m
Construction is MFMDF carcases
The sliding door in the above picture will slide into a pocket created by the carcases when finished.
Jump forward a bit about 50 samples of the white washed oak and lots of veneering later and it's finished .
The doors have a 30 degree angle cut onto the edge to allow the doors to open against the white lacquered frames.
It's been a nice project and a nice challenge getting the detailing right from the architects blueprints. Biggest challenge was getting the grain flowing through from side to side and managing to veneer everything the right way up etc as one mistake would have ruined the whole front. There is also a nice forum connection as a friend who I have made through the forums recommended me to his friends for the job.
Thanks for looking
mailee
Re: Big old cupboard thing
Post by mailee » Thu Aug 07, 2014 8:50 pm
That is one hell of a cracking job Jon. How did you veneer the MDF, it must have been too large for the bag press? Bet that took a lot of patients. :D
Post by thatsnotafestool » Thu Aug 07, 2014 9:09 pm
Wow, mate! Top job.
How did you shoot the veneers when you joined them together?
Post by jonnyd » Thu Aug 07, 2014 9:31 pm
Hi guys the doors were bag pressed as the doors were made individually and the large layon cut up with a knife to get the layons for each door.
Veneers were shot with a veritas jack plane on a big shooting board jig.
siafins
Post by siafins » Thu Aug 07, 2014 9:51 pm
Stunning!
furynaturre
Post by furynaturre » Thu Aug 07, 2014 9:57 pm
Jonny,
That is just awesome, First class work!
I hope they are going to change that georgian glass door, and the placcy switches!
That is just my sort of thing, lovely jubbly!
James
Micmoc
Post by Micmoc » Thu Aug 07, 2014 10:33 pm
Wonderful !
Post by senior » Fri Aug 08, 2014 6:52 am
Really nice Jon. Why make it up as a 2.5 x 5m veneer when there are 4 vertical breaks in the units?
Post by woodsmith » Fri Aug 08, 2014 7:45 am
Fantastic work! Does the 30 degree angle on the doors allow for a finger pull or are they push to open?
It would have been interesting to see a shot with a few doors open.
Post by jake » Fri Aug 08, 2014 9:35 am
Very nice, Jonny.
Post by jrm » Fri Aug 08, 2014 10:10 am
Excellent work and a brilliant result. It's a good job you have a big workshop. 2.5m x 5m jointed veneer :shock:
Post by karl » Fri Aug 08, 2014 10:12 am
Excellent work Jonny - love it.
Post by JonR » Sun Aug 10, 2014 8:43 am
Nice job there mate, can ask if i may did you solid lip the edges or iron or use an edgebander after the face veneer and also what glue did you use for the bag pressing work ?
Post by jonnyd » Sun Aug 10, 2014 2:48 pm
Thanks for the comments guys.
senior wrote:Really nice Jon. Why make it up as a 2.5 x 5m veneer when there are 4 vertical breaks in the units?
Yeah it was done like you said veneers laid up to the vertical breaks and then cut out then carry on with the next lot so was never actually a great big bit of veneer as it were
furynaturre wrote:Jonny,
James
I will pass you notes on to the architect who hand sprayed the switches with Matt white paint to make them look like plastic :lol: the Georgian doors are going flat being replaced with solid lacquered Matt white ones I think.
woodsmith wrote:Fantastic work! Does the 30 degree angle on the doors allow for a finger pull or are they push to open?
Yes the 30 degree chamfer is the door pull. The 30 degree angle is only on the edges adjacent to the white squares
JonR wrote:Nice job there mate, can ask if i may did you solid lip the edges or iron or use an edgebander after the face veneer and also what glue did you use for the bag pressing work ?
The edges were lipped with solid wood 7 mm thick for the regular sides and a wider 13mm strip for the edges with the handle. Mdf lipped first then edges flushed then veneered on top. Veneer glue was uf resin Borden ul39
Post by senior » Sun Aug 10, 2014 4:41 pm
As said it looks fantastic, great bit of design as well as making.
Post by jonnyd » Sun Aug 10, 2014 5:21 pm
Cheers bobby
furynaturre
Post by furynaturre » Sun Aug 10, 2014 9:58 pm
Architects... Matt white light switches, they won't look like they've been nailed to the wall in a Kwick Fit staff room inside 6 weeks will they? :roll:
Truly lovely work never the less, hand venereed things like that always grab me, it's a subtle way to show real quality!
Post by Doug » Sun Aug 10, 2014 11:39 pm
You know I think it looks great Jonlar
Post by promhandicam » Mon Aug 11, 2014 7:55 am
That's come out very nicely Jon. Doing a job like that is always slightly worrying until it's completed, but when you've finished and the customer is happy it makes it all worthwhile - at least in my experience.
