Past project
Past project
Hi retired now but I’d like share some photos of a previous job as tangent handrail and staircases are in focus at the moment. This staircase and handrail are not perfect in anyway. I was called on to make this as I had done a lot of work for the client. I’ve never made a staircase or handrail like it before or after. I learnt a lot doing it all made on site (no workshop).
Re: Past project
That's really nice
Re: Past project
Well you certainly passed with flying colours, Great job.
Re: Past project
A couple of pictures showing practice pieces of tangent handrails, made just for fun to prove my drawings were correct. not related to the staircase above.
Re: Past project
The drawings above are a way of solving two equal pitched handrails that are at different height to each other but need to come together on a quarter turn. Not complete but very nearly all the geometry should be easy enough to follow.
Re: Past project
After a lot of head scratching, I'm struggling trying to figure it out. I'd really appreciate if you could critique my understanding so far.
The critical point is shown by the arrow? Yes? You strike two arcs centred at A and B. A arc radius is the length of the inclined tangent. B arc radius is the length of the tangent.
From that intersection of the two arcs, you strike a line back to A. This is your ‘new’ pitch line.
You then extend that down in the 7 o’clock direction to intersect the second inclined tangent of the lower hand rail at C ?
I see you mention an easing. Is this a separate piece of timber added to one end of the wreath ?
If so, how do you decide it’s curve…ie why it terminates at D on the second inclined tangent ? And not further down or above ?
What’s the relevance of the two 90 degree lines ?
I don’t see the bevel anywhere ?
The centreline of the facemould is in green ?
TIA
TIA
Re: Past project
Hi
Yes the critical point is shown by the arrow.
A to the arrow is the length of the inclined tangent.
B the length of the tangent in PLAN view.
The level tangent and inclined tangent must meet at that point along the horizontal line.
The angle of that line is determined by the difference in height between the two pitches, and how much height you want the easing to take up. It must still meet at the junction of the two inclined tangents at A( the reason you have this problem is because the upper flight is to far onto the landing, if you could slide the top flight towards the trimming you could bring them so you could have them at the same height) but this can’t be done hence the problem.
From the arrow to point D is the start and end of the easing, this can be what you want, the tangents of the easing need to be at 90 deg in both directions so they join to the wreath and lower handrail also cut at 90 deg cut in both directions.
The easing can be incorporated into the wreath but I don’t think you should try this it not beginning stuff, as is any of it. I have drawn it as a separate piece. I haven’t drawn it but you should include about 50mm on the end of the easing and the wreath that joins a straight handrail, so that your joining straight to straight. ( hope that makes sense.
The relevance of the two 90 deg lines is answered two paragraphs up.
The curve of the easing is determined by drawing two lines at 90 deg to the tangents at the joints , they should intersect that is the radius point.
Very important you pay attention to the ordinate direction it won’t or shouldn’t be corner to corner of the square encompassing the plan radius ( the line with the small circle on it).
The easing terminates at D because it reaches the lower pitched handrail which is tangential to the curve of the easing.
This is very precise work, everything joins at 90 deg both ways
The centre line of the facemould is in green but terminate where it joins the inclined tangents and is a perfect ellipse. Don’t forget add 50mm to the wreath at the straight handrail end.
The lower bevel is developed the same way as the “this is carpentry post” the upper bevel is different, I thought you could try to work that out for yourself, I will help but I hope you don’t mind me saying this is a very steep learning curve. And a bit of research might be fun?.
Hope this is clear.
Hope this is clear.
Re: Past project
Hi
Yes, level and inclined tangents in blue.
Re: Past project
Shock and awe, mate. Shock and awe. Your understanding of all of this is nothing short of amazing and I salute you. All of your points are well-made.
As you say...a vertical learning curve. Thank you, thank you for your support.
Re: Past project
Thanks for you comments, and thanks to MJ80 and Meccarroll for there kind comments, I find the more I learn and understand, the more I need to learn. It is head scratching but in a good way.thatsnotafestool wrote: ↑Thu Mar 25, 2021 10:01 pmShock and awe, mate. Shock and awe. Your understanding of all of this is nothing short of amazing and I salute you. All of your points are well-made.
Re: Past project
I feel like having a go for a test.
Re: Past project
Whoops I made a boo boo, in this case the upper bevel is developed the same way as the “this is carpentry post” I’ve double checked two ways so confident now, as far as I can see everything else is correct.Oldboy22 wrote: ↑Thu Mar 25, 2021 7:04 pmHi
Hope this is clear.
Re: Past project
Here's a thought...is there any chance we could have a Zoom session (I can set that all up ) and watch how you create the drawing you've posted above ?
Or we could use SketchUp via Zoom, if you're not familiar with SketchUp then I'd be your 'compass and protractor' and you'd guide me through it. Anyone interested could watch and contribute.
Re: Past project
Sorry I can’t do that!, I’m very happy to help but only via the forum.thatsnotafestool wrote: ↑Fri Mar 26, 2021 2:19 pmHere's a thought...is there any chance we could have a Zoom session (I can set that all up ) and watch how you create the drawing you've posted above ?
Let me know what part your having difficulty with and I’ll draw just that stage.
This is very flattering but I’m not an expert or a teacher, just an old site carpenter who’s read a few books.
Re: Past project
So..the extra constructs (A to the arrow etc) are there purely to create the design details for the easing ?
By 'level' tangent, do you mean the line B to the arrow ?
Here's a photo from my set-up. I extended the line of the two centre-lines for the straight part of the handrail on the upper flight and lower flight and as you can see they don't meet due to the height difference which in my case is 115mm. So I'd plug that into my drawing to create the line you've shown dotted (C > D). I've noted on your drawing where I think the 115mm would be used.
The redlines are created after this new tangent is drawn..yes ? But I'm not sure what they are used for.
Understand the first sentence but have a mental block understanding the next one. TBH I have a block trying to understand why there is the height difference giving me this problem when the treads on the upper flight, quarter-turn platform, lower flight have all the same rise.Oldboy22 wrote: ↑Thu Mar 25, 2021 7:04 pmThe angle of that line is determined by the difference in height between the two pitches, and how much height you want the easing to take up. It must still meet at the junction of the two inclined tangents at A( the reason you have this problem is because the upper flight is to far onto the landing, if you could slide the top flight towards the trimming you could bring them so you could have them at the same height) but this can’t be done hence the problem.
I think what you're saying is that all the joins need to be cross cut on a virtual mitre saw at 90 degrees ?
Now this is where I'm struggling. We start off drawing the wreath based on the radius of our turn and end up with the length of the wreath needed to wrap around that virtual cylinder and fill the gap between the ends of the straight handrails on the two flights. But we're also adding in the length of the easing which I find hard to get my head round. How long is the easing ?Oldboy22 wrote: ↑Thu Mar 25, 2021 7:04 pmThe easing can be incorporated into the wreath but I don’t think you should try this it not beginning stuff, as is any of it. I have drawn it as a separate piece. I haven’t drawn it but you should include about 50mm on the end of the easing and the wreath that joins a straight handrail, so that your joining straight to straight. ( hope that makes sense.
Pointed at by my blue arrow.
I don't understand this - sorry. The ordinate direction ? Being a bit thick.
Understood
So the 'designed' length of the wreath is from X to Y. These are the shanks. Cut at our virtual 90 degree cross cut on a mitre saw...but we then add to the wreath 50mm straight pieces at either end ? Why ? If the wreath is made to the drawing then surely there is no need ?
Many thanks again for your help. This is one of the most frustrating concepts that I've encountered. Just when I think I've cracked it, it kind of slithers away again
Re: Past project
Hi
Okay I’ve assumed to much. If you lay a straight edge on the upper string and another on the lower string , the height difference must be between the underside the lower straight edge and the underside of the upper straight edge.?? Assuming the margin on the strings are equal?.this should be the height difference.
I’ve decided to draw it in stages so we can agree on and fully understand the first stage before going on to the next.
First stage.
First stage.
Re: Past project
Yup...understand the height difference..I know the arrow in my picture is confusing.
Thank you for those drawings...that helps a lot.
Re: Past project
Anyone else got a question ?
I’ll go to the next stage when you understand.....
Re: Past project
Ok so far, thanks.
Re: Past project
This is superb, thank you.
Re: Past project
Any questions?
Re: Past project
Am I right in saying that the amount of height chosen to be in the wreath and that in the easing is down to experience ?
Re: Past project
I don’t really have to much practical experience, I’ve only ever made the one staircase that needed a tangent handrail, but it seems to me the bigger the plan radius and the more gentle the easing the smoother the transition.thatsnotafestool wrote: ↑Sat Mar 27, 2021 3:52 pmAm I right in saying that the amount of height chosen to be in the wreath and that in the easing is down to experience ?
Re: Past project
That makes a lot of sense to me. The flow is so important.
Re: Past project
Stage 4
Transferring the centre of the radius up to the ellipse base line.....
Copy or offset the ordinate line in the plan to the centre of the circle in plan, then continue vertically where it touches the base line to the extended upper inclined tangent.
Then copy or offset the other ordinate line from where the vertical line touches extended tangent line.
Where it touches the ellipse base line is the centre of the ellipse.
Do the same with the end of the circle in the plan , this will be the end of the semi-major axis of the ellipse, as show in the drawing.
Re: Past project
Stage 5
You should now be able to draw the ellipse and it should just kiss the inclined tangents.
Re: Past project
OK...I got this the wrong way round the first time I read through it. So just to clarify the sequence - for me and any others....
The blue line
The green line
The red line
At M
This last bit I don't follow. Could you perhaps highlight this line, please. Do you mean drawing that semi-circle pointed at by the blue arrow?
Re: Past project
Hi they must be the same angle as the ordinate or vertical between the horizontal base line and the inclined tangent, like your blue, green and red line.
I’ve highlighted in magenta the line that develops the end of the ellipse.
Re: Past project
Perfect. Thank you. The other end of the ellipse you do by eye?
Although I've now got my walnut, as I've got a slab of 200mm x 100mm softwood, I'm going to redraw this tomorrow, make the wreath and see what comes out in the wash.
Re: Past project
Hi no nothing is done by eye, if you have an ellipse function on your drawing package you only need the semi-minor axis which is the radius of the circle in the plan and the semi-Mayor axis which is from the centre to the magenta line. The ellipse ends at the end of the inclined tangent lines. I don’t think your quite ready to start cutting yet where are the bevels and wreath drawings.
Re: Past project
Ooops....you're right. This is brilliant though.
Re: Past project
Hi
Here’s a reposting of my original drawing that should show any construction lines I missed drawing the stages.
Re: Past project
Hi Oldboy22, just wondered which book you used for reproducing your drawings.
I know there are lots out there each with a different way of tackling the subject and some jump in showing Plates which at first sight don't seem very interesting but they actually deal specifically with a specific handrail combination.
The terminology which you used sort of indicated you were referencing a book:
"The easing can be incorporated into the wreath but I don’t think you should try this it not beginning stuff"
I don't think I have come across it as yet but it would be interesting to know what you are reading.
Morris Williams, STAIR BUILDERS GUIDE is a good read
And Robert Riddle has published a few good books too.
