Extra deep rebates for the dgu. Ellis says that only the best quality work had horns on the inside and outside sashes, so I went for plenty of horn.
Dummy glazing bar, scribed then glued and screwed through the rails with epoxy. All the other joints were done with PU - really crappy make I haven't used before called Lumberjack. Absolute bugger to clean off, as you can guess from the middle picture.
Mouldings on the sashes were done with a set of Wealden narrow sash cutters here Really good cutters and not too expensive, as usual - don't go anywhere else for router cutters now. Cunning plan for hanging the wagtails - a bit of 6mm steel, 2 bits of plastic tube:
