Cat flap
Cat flap
Postby jake » Sun Nov 06, 2011 8:55 pm
I was telling Jase about this last night.
I had a door being planned in my head for the entrance to the kitchen/diner. It has to be glazed (I am instructed) so gunstock stiles, and margin glazing bars (I think that's the right terminology).
I dropped off my kid at a party yesterday, and as it is minutes away from a reclaim yard I went and had a mosey. Idly checked the doors, and there was exactly my door. But an inch too wide I thought, but actually it's only half an inch so all is well. For £80, I couldn't resist as although making it would be more interesting than renovating this one, it would take longer.
Anyway, it's a good lesson in how to fit a cat-flap to a really nice door.
Re: Cat flap
Postby jonnyd » Sun Nov 06, 2011 9:20 pm
Save some time and get a cat :D
Looks like a nice door
Re: Cat flap
Postby Mr Ed » Sun Nov 06, 2011 9:28 pm
I like the coloured glass, should all clean up nicely
Ed
Re: Cat flap
Postby modernist » Sun Nov 06, 2011 10:27 pm
A very nice example, lovely proportions and glass. You have to wonder at the mentality of the cat owner. Clearly not a woodworker. Are you going to dismantle it or try to sort it as is?
Re: Cat flap
Postby jake » Sun Nov 06, 2011 10:40 pm
I'm going to try to keep it together if I can, but if it needs to come apart, so be it. The bottom rail is the obvious surgery, but the mid-rail has also been twatted by someone fitting a really tall sash lock.
One of my fave bits is the skinny lambs-tongue glazing bars.
The deep bead on the hinge side I have not seen before on a door (not that my experience is particularly meaningful). On the reverse side, it is bevelled off to the depth of the bead. The stiles are unequal width (by the depth of the bead, obviously). All for a bit more strength on the hinge side, I assume.
Re: Cat flap
Postby modernist » Sun Nov 06, 2011 10:58 pm
jake wrote:I'm going to try to keep it together if I can, but if it needs to come apart, so be it. The bottom rail is the obvious surgery, but the mid-rail has also been twatted by someone fitting a really tall sash lock.
It's difficult to see clearly but maybe the original hinges were the same width as the bead on the pivot side, so hiding the hinge and bevelled on the non-hinge visible side to make the stiles look even. Jacob would know.
I love gunstock doors, especially with fine glass like that. I think it is the top of the door maker's art when the proportions are right. As I've said before my favourite is the Scottish version with very low middle rail and rounded corners around the glazing (still can't find the pic) used often in Victorian Gothic stuff.
Re: Cat flap
Postby jake » Sun Nov 06, 2011 11:19 pm
modernist wrote:
jake wrote:The deep bead on the hinge side I have not seen before on a door (not that my experience is particularly meaningful). On the reverse side, it is bevelled off to the depth of the bead. The stiles are unequal width (by the depth of the bead, obviously). All for a bit more strength on the hinge side, I assume.
Oh definitely so, the original hinge recesses are about as deep as the bead (see the catflap picture). So that's part of it, but I assumed there was more reason to it than just the decorative nicety of having a bead match the hinge knuckles.
The bevel is cunning. I knew the bead trick of evening up french door stiles, etc, but the bevel works better than I would have thought if it had been described to me.
Re: Cat flap
Postby mrgrimsdale » Sun Dec 04, 2011 11:25 pm
jake wrote:I'm going to try to keep it together if I can, but if it needs to come apart, so be it. ......
Almost impossible without breaking the glass, unless you can chip the putty away very slowly like a dentist (I'd ask a dentist to do it!).
Re: Cat flap
Postby mrgrimsdale » Sun Dec 04, 2011 11:37 pm
jake wrote:....
Could be a matching bead has been taken off the opp side?
Hinges often set in invisibly to a bead same shape as hinge knuckle, but on furniture more often.
Re: Cat flap
Postby jake » Sun Dec 04, 2011 11:51 pm
mrgrimsdale wrote:
jake wrote:....
Possibly, I'll nose around for clues.
And yes, obviously I know why it is beaded, not that I have seen it on a (doorway) door before.
Re: Cat flap
Postby mrgrimsdale » Mon Dec 05, 2011 9:20 am
jake wrote:.... not that I have seen it on a (doorway) door before.
Nor me as far as I remember. But it's a posh door probably from a public building (shop?) where little flourishes of added value are the thing.
Re: Cat flap
Postby nickw » Mon Dec 05, 2011 10:43 am
Unless you cough up for a putty lamp. Though they can be hired.
Re: Cat flap
Postby thatsnotafestool » Tue Dec 06, 2011 5:57 pm
Nick, you beat me to the putty lamp but I can suggest a much much cheaper rental from Mears Architects...very helpful folk. And they are in London.
It takes only a couple of minutes, if that, to soften up the putty. Using one is a no-brainer.
Re: Cat flap
Postby houtslager » Tue Dec 06, 2011 10:57 pm
OUTTA CURIOSITY whar light does yje lamp us ; uva , uv b , or infra red ?
k
Re: Cat flap
Postby tusses » Wed Dec 07, 2011 7:41 pm
houtslager wrote:OUTTA CURIOSITY whar light does yje lamp us ; uva , uv b , or infra red ?
k
hey Houts' ... I think your keyboard is busted !
Re: Cat flap
Postby thatsnotafestool » Fri Dec 09, 2011 10:36 pm
k
Infra-red but of a certain wavelength that goes straight through the glass. All the stuff is in the link I gave on another thread where some of them got arsey. viewtopic.php?f=7&t=7498
Re: Cat flap
Postby jfc » Fri Dec 09, 2011 11:00 pm
A cheap shot would be me thinking you are a bit of a d*ck, and then putting it on the forum, but I didn't, I just think it.
:lol: :lol: :lol: :lol: :lol: :lol:
Re: Cat flap
Postby thatsnotafestool » Fri Dec 09, 2011 11:38 pm
I'm gonna eat your fish :lol:
Re: Cat flap
Postby mattty » Sat Dec 10, 2011 9:42 am
thatsnotafestool wrote:I'm gonna eat your fish :lol:
Is that a euphemism?
Re: Cat flap
Postby thatsnotafestool » Sat Dec 10, 2011 11:16 am
No..maybe some sole searching
or keeping Jas in his plaice
but then it might simply be codswallop! :D
Re: Cat flap
Postby mattty » Sat Dec 10, 2011 1:35 pm
Get back on your Perch Rog
Re: Cat flap
Postby thatsnotafestool » Sat Dec 10, 2011 2:23 pm
mattty wrote:Get back on your Perch Rog
:D
Re: Cat flap
Postby jake » Mon Feb 18, 2013 8:45 pm
So, turned back to this after a long diversion on doing up a bathroom and toilet. Most of the hard work was done ages OK, and it is now de-catflapped and has about half a new stile on one side - the wood was totally shot, dipped probably. I routed off the crap and grafted some ceiling wood tm on with epoxy to replace it. Sacrilege probably but it's going to be painted so oh well.
I wanted to replace the (badly done) putty with mouldings given it is going to be an internal door in its new life. I lost most of the margin glass - some was already cracked, there were only about two which looked original in fact. The starbursts were OK, so I got the putty off with a hot air gun - heat for a few seconds, shielding the glass with a scraper.
Put the gun down, then scrape off the softened putty. Turn around to pick up gun, repeat. Turn around to pick up gun, oh f**k and b*ll*cks:
Some more sacrilege with panel pins and two-part filler followed. For shame.
Re: Cat flap
Postby jake » Mon Feb 18, 2013 9:23 pm
So anyway, a bit of tweaking needed to the hanging and some of the leading edge will need to be shaved to get it to close, but it is up and ready for painting. I hate painting.
Re: Cat flap
Postby noel » Mon Feb 18, 2013 10:05 pm
Looking well and nice collection of cooky books. How old do you reckon the actual door is?
No disrespect but that other door may need some attention.
Re: Cat flap
Postby jake » Mon Feb 18, 2013 10:18 pm
noel wrote:Looking well and nice collection of cooky books. How old do you reckon the actual door is?
Victorian I think, probably late-ish, but I'm no expert.
Hah. Yes. The poor old cellar door. It's on the list. My house has a few contrasts like that (all over the place). All it really needs some mouldings, a lick of paint, and some door furniture but if you start painting that then all the whole staircase surround it is set in starts needing a coat of paint too, and then the balusters of the staircase itself too, which is about where I give up the will to think about it...
billybuntus
Re: Cat flap
Postby billybuntus » Wed Feb 20, 2013 6:59 pm
I was just about to say be careful with those brilliant cut stars as they are around £30 a piece (new) at the moment.
But looks like your doing a great job :-)
Re: Cat flap
Postby mattty » Wed Feb 20, 2013 7:14 pm
Nice one Jake. I love the hot air gun story. We need a confessions board on the forum.
Re: Cat flap
Postby modernist » Wed Feb 20, 2013 9:47 pm
I like the look of that door Jake and the glass is nice.
Re: Cat flap
Postby jake » Wed Feb 20, 2013 9:54 pm
Thanks for comments all, and yes replacement glass was not cheap. Even the clear stuff, but then it has nice bumps and wibble-wobbles in it and a bubble or two.
