new dust mask / respirator ?
Postby tusses » Sat Jul 15, 2017 5:35 pm
just getting ready to buy a new mask/ or cartridges for the one I have.
which is this one http://www.ebay.co.uk/itm/Gerson-9000E- ... SwH09ZJZsj
has twist on cartages, and disposable prefilters ..
I used to do more painting .. hence having a paint respirator
and have just stuck with it since out of habit
Assuming if it filters out paint/solvent fumes, then MDF dust should be no problem .
You know what ASSUME does ! lol ...
What do people think ?
What would you choose ? what do you use ?
My workshop is constantly full of fine MDF dust .. which is my main concern.
Secondly, I will be using a bit more paint and solvent finishes for the short term .. maybe more if that product line takes off. I've never been impressed with water based dyes and finishes.
Yes .. I know I should be getting rid of dust at source .. , but for now, I wear a mask :oops:
Re: new dust mask / respirator ?
Postby promhandicam » Sat Jul 15, 2017 7:55 pm
I've been using the 3m 4251 masks for a while and stick with them as they are relatively comfortable. Currently £18 in screwfix. I also have some disposable pre filter papers that fit across the front which are good at removing a lot of dust and prolonging the life of the mask. Probaby a comfortable mask is the most important thing as you won't be discouraged from wearing it.
Postby tusses » Sat Jul 15, 2017 11:45 pm
Cheers Steve .
Mine are comfy . When the CNC is going I wear it all day practically .
It was more that I've been buying/using the same system for about 10 yrs , that I thought I'd check and see what everyone else is using these days
Price wise, the replacement cartridges for mine are about £18 ish, so not much in it. And I know they are ok for VOC and 2K
Rich
Postby woodsmith » Sun Jul 16, 2017 1:57 pm
If you are using a mask for MDF dust you need one rated P3. The one you link to doesn't seem to have a rating at all so I would assume it is only for paint/solvent use. I have used 3M 7000 series masks for years and they are very good (. I hope)
Postby tusses » Sun Jul 16, 2017 3:36 pm
this is the cartridge
http://www.gersonco.com/product/gerson-g02e/
and this is the prefilter
http://www.gersonco.com/product/gerson- ... d-082814c/
you know .. I never considered it before ? I have no idea why not ...
Postby tusses » Sun Jul 16, 2017 3:56 pm
Looks like I'll be getting something more suited to MDF dust ......
Postby woodsmith » Mon Jul 17, 2017 8:12 am
The pre filter is rated P2, so not too bad, but I would definitely go for a dedicated P3 mask if I were using MDF a lot.
Postby tusses » Tue Jul 18, 2017 5:53 pm
yes , a little bit reasuring .. they do a P3 prefilter , but can't find it in this country.
about £5 a pair from the nether regions .. plus post.
So might get the one Steve said about, for when using MDF only
Postby promhandicam » Tue Jul 18, 2017 8:37 pm
Just had a quick look, and the 3m mask is only P2 rated (whatever that means)
Postby tusses » Wed Jul 19, 2017 9:01 am
ah, ok .. same as mine then.
the P is for particulates. 1,2,3 .. with 3 being the best / removing the most
I'll have to look at removing dust more at source. And also use my air cleaner again.
wallace
Postby wallace » Wed Jul 19, 2017 6:14 pm
Like already said you really want P3 rating for long term exposure. Have you thought about a decent powered one. I used the 3m dustmaster for a few years until the batteries died I then went to a 3m versiflo which are p3, much better than wearing a mask. Really silly money when new but they come up on ebay cheaper.
