Hi all currently making this unit for a spare bedroom and need some under-mount draw runners. I am going to make a box for the draw and fix a front to it.
The dimensions are 530mm deep about 200mm high and about 800mm wide. It will only hold clothing and light items. Any suggestions?
TIA Mark
Draw runners?
Re: Draw runners?
Got this sorted, I have ordered some Blum tandem, blumotion draw runners (full extension).
Buying these draw runners from main retailers the cost would be around £36 for a pair or more including p&p. Eventually I found a seller on eBay selling a set at £26 so made the purchase. It was the p&p that was putting up the price from the main retailers as they only seemed to use next day delivery and the charge was high for one item.
Re: Draw runners?
Mark,
These are a cheaper option for the future
https://www.jsfurniture.co.uk/furniture ... etail.html
Re: Draw runners?
Cheers for that Paul, looks very similar fitting instructions to Blum. Habe you used them and if so what do you think of them?cncpaul wrote: ↑Wed Sep 09, 2020 6:31 amMark,
Re: Draw runners?
Stick with blum movento. Best there is and smooth closing action.
Re: Draw runners?
Accuride make good runners too depending on what you are using them for.
Re: Draw runners?
Just fit the Blum runners I ordered this morning and have got to say they were fairly simple to fit and work really nice.davidpidge wrote: ↑Thu Sep 10, 2020 8:50 pmStick with blum movento. Best there is and smooth closing action.
