Achieving a perfect 45 degree chamfer.
Post by mrgrimsdale » Wed Jul 09, 2008 6:26 am
Been peeking over there but don't want to blow my multiple identity cover so will have a go at answering over here instead.
It seems they are struggling with yet another crap gadget which makes an easy job more difficult.
The way to do it IMHO is:
through chamfer; by eye with a jack plane (long plane for straight edge) or to marks (advisable!)
stopped chamfer; to marks, work the ends first with a chisel, then join them with a block plane. If too short for a plane then do the whole thing with chisels, a few saw cuts speeds up waste removal.
Or use a router, but a stopped chamfer still needs ends hand working.
Worst option is http://www.leevalley.com/wood/page.aspx?c=3&p=46296&cat=1,41182 don't waste your money!
Jacob
PS crap gadget merchants not only sell you the useless "Mark 1", but then come up with the improved (but still useless) "Mark 2", then attachments etc etc. ;D ;D
PPS and to Kevin in Keswick I'd suggest not to buy any more tools he obviously has too many, but to buy a load of wood instead.
wizer
Post by wizer » Wed Jul 09, 2008 8:07 am
What makes 'Mark 2' crap?
Post by mrgrimsdale » Wed Jul 09, 2008 8:11 am
Generalising about gadgets which are usless to begin with and each "improvement" goes nowhere as the idea is crap from the start. Honing jigs spring to mind, though I know not everybody agrees with me!
ches
Jacob
johnboy
Post by johnboy » Wed Jul 09, 2008 8:23 am
Have to agree Jacob. If I've got a lot to do then then a router is fast and accurate otherwise a hand plane. No marking out for small ones but just run a pencil down the timber using my finger as a stop and plane to the lines for bigger ones.
Cheers John
wizer
Post by wizer » Wed Jul 09, 2008 8:24 am
I think in this case the 'gadget' was greatly improved, at the manufacturers expense, which lead to the product being re-designed. Even the shimmed version worked exactly how it's supposed to. It's not expensive, I think I'd buy one. Better than the noise of the router.
toobyefore
Very Regular Poster
Post by toobyefore » Wed Jul 09, 2008 10:00 am
"Achieving a perfect 45 degree chamfer"
I'd have thought the nub of the problem was why it has to be "perfect"
Cheers, Alf
Post by jfc » Wed Jul 09, 2008 11:08 am
I cant even peep over there as my IP is blocked ::)
Andys Woodshed
Post by Andys Woodshed » Wed Jul 09, 2008 11:31 am
Alf wrote:"Achieving a perfect 45 degree chamfer"
Cheers, Alf
Spot on Alf
But it could be so they can be checked with those little brass mitre gauges Image
daves
Post by daves » Wed Jul 09, 2008 12:12 pm
jfc wrote:I cant even peep over there as my IP is blocked ::)
change it then! ::)
jay
Post by jay » Wed Jul 09, 2008 12:34 pm
That little gadget has its uses. I've been making some octagonal tool handles that I wanted to look reasonably smart and it did alright at keeping me from going all wonky.
You have a fixed IP address? Ignore me if I'm teaching you to suck eggs, but IP addresses cost money - Internet Service Providers rely on the fact that the odds of everyone wanting to use the internet at the same time are slim and only buy so many. Unless you've specifically purchased a fixed IP address, your IP address will be asigned, effectively at random, from your ISP's pool of spares when you log on and will be given up again and lost to another customer when you log off.
The upshot of which is that it's very very unusual to be able to identify and ban someone using their IP address.
Post by mrgrimsdale » Wed Jul 09, 2008 12:44 pm
PM on it's way
Well yes, but also the question asked by all learners and developers: is it me or the kit?
9 times out of 10 it'll be you, not the kit, and you need more practice. In fact more kit can stunt your growth in skill development, and make you dependant for life!
Jacob
Post by paulchapman » Wed Jul 09, 2008 12:52 pm
Do they have brass knobs ??? ;D
ocicat
Post by ocicat » Wed Jul 09, 2008 8:33 pm
Internet Service Providers rely on the fact that the odds of everyone wanting to use the internet at the same time are slim and only buy so many. Unless you've specifically purchased a fixed IP address, your IP address will be assigned, effectively at random, from your ISP's pool of spares when you log on
That may have been true on dial up, but despite not being guaranteed a fixed IP on broadband (unless paying business etc) you will find your IP address is constant for months.
Regarding the chamfer Router perhaps for stopped, or by hand plane or spoke they are not that hard to do??? each pass tells where to place the emphasis on the next pass, it's all about feel.
Alan
Post by mrgrimsdale » Wed Jul 09, 2008 9:17 pm
ocicat wrote:snip
Or years in my case; a small local ISP. There is however a growing number of free proxy server websites which get around the problem. Seems to be a new phenomenon as far as I know
Alan
Agree. And quicker and easier than a gadget ;D . Is a fundamental and recurring issue; whether or not you need better kit, or more practice.
Jacob
Post by thatsnotafestool » Thu Jul 10, 2008 11:41 am
But surely the point of this gadget is so that we can get that 'freshly machined look' that us hand tool users all strive to achieve yet rarely succeed ;)
daves
Post by daves » Thu Jul 10, 2008 12:18 pm
ocicat wrote: That may have been true on dial up, but despite not being guaranteed a fixed IP on broadband (unless paying business etc) you will find your IP address is constant for months.
True, but I've found that if I disconnect my router (or my modem, when I used one) and leave it disconnected for a while, I get a new IP when I reconnect.
Dave
Post by mrgrimsdale » Fri Jul 11, 2008 8:31 am
Been over there again - they are getting their heads around freehand etc - and pencil marks! That's progress ;D well I thought so but they seem to have a problem actually making the marks. Luckily someone came up with this brilliant solution ;D ;D no comment.
What I do is run a combi square down, with a pencil held against it, if I want to be super accurate. Otherwise as johnboy said earlier - use your fingers as a stop.
Jacob
Post by paulchapman » Fri Jul 11, 2008 8:53 am
Blimey, Jacob, you're becoming just like one of those Daily Mail writers........... ::) ;D
toobyefore
Very Regular Poster
Post by toobyefore » Fri Jul 11, 2008 11:27 am
Have I mis-read that price...? :o For a pencil gauge. Even with my natural attraction to bling on tools that's outrageously idiotic.
Cheers, Alf
Post by mrgrimsdale » Fri Jul 11, 2008 11:40 am
Yebbut you get a free pencil with it
Post by paulchapman » Fri Jul 11, 2008 11:57 am
;D ;D
toobyefore
Very Regular Poster
Post by toobyefore » Fri Jul 11, 2008 12:00 pm
Only one; and a bloody short one at that. >:(
dunbarhamlin
Post by dunbarhamlin » Fri Jul 11, 2008 1:26 pm
Yebbut, at least you'd make darn sure you always knew where one of your pencils was :D
Can't deny getting itchy and sweaty over antipodean marking tools - for a pro, I'm sure the cost couldn't be justified, but even disregarding the quality of finsh, pretty woods, brass and shellac, the functional niceties do put them in a world apart from marples and the like.
Steve unashamed blackwood-and-brass-phile
Though no - I don't have a pencil gauge
yet :-[
toobyefore
Very Regular Poster
Post by toobyefore » Fri Jul 11, 2008 1:42 pm
Yebbut, Steve, by the very nature of the beast it's not as though a pencil gauge needs to be anything but bog standard basic. Oh well, whatever floats your boat, as the saying goes. ;D
Cheers, Alf
Post by paulchapman » Fri Jul 11, 2008 1:43 pm
dunbarhamlin wrote: unashamed blackwood-and-brass-phile
Hi Steve,
I had a look at those Clenton gauges when I was down at West Dean and, while they are superbly made (bit of an understatement ;D) I concluded that my home-made gauge was, in terms of practical functionality, just as good - in fact it's the one I reach for every time these days
And the bonus is they cost nothing as you can make them from scraps of wood lying about in the workshop - and make as many as you like. In fact it would look quite nice in African Blackwood - might buy a bit and give it a go as I need some more gauges.
dunbarhamlin
Post by dunbarhamlin » Fri Jul 11, 2008 1:53 pm
Hey I'm denying nothing - but it's got to be better than a penchant for shrunken heads (or, worse still, weetabix boxes) :D
Fab stuff Paul - now you just need to check with her indoors - if she doesn't mind being called Sheila you could make a killing flogging them to hapless poms ;D
I do make bits and pieces for the bench, but somehow only a panel gauge on the gauge front so far.
Though on the subject of pencil gauges, think I came up with a decent collet design for a homebrewed one using clutch pencil leads this lunchtime - will have to get some tapping things to play around (not much of a metal worker - does it show?)
Post by mrgrimsdale » Fri Jul 11, 2008 2:15 pm
Yebbut, thats a nail though, innit?
Post by paulchapman » Fri Jul 11, 2008 2:19 pm
mrgrimsdale wrote:Yebbut, thats a nail though, innit?
Well spotted, Jacob. Yes, it's a masonry nail - works really well when ground to a suitable shape.
Post by mrgrimsdale » Fri Jul 11, 2008 2:36 pm
dunbarhamlin wrote:it's got to be better than a penchant for shrunken heads (or, worse still, weetabix boxes)
Who told you about my weetabix boxes?
Jacob
toobyefore
Very Regular Poster
Post by toobyefore » Fri Jul 11, 2008 3:14 pm
dunbarhamlin wrote:Hey I'm denying nothing - but it's got to be better than a penchant for shrunken heads
Okay, who blabbed...? >:( ;D
Cheers, Alf
Who denies everything on principle
dunbarhamlin
Post by dunbarhamlin » Fri Jul 11, 2008 3:49 pm
Dammit try and find examples outlandish enough to make my perversions look humdrum and they ALL start poking their heads out of the woodwork.
Next will even find some weirdo who keeps thinly sliced christmas trees under the bed.
(Oops, that'd be me - I'll just go bury my head in Grimshaw for a while)
Post by paulchapman » Fri Jul 11, 2008 10:27 pm
Have you had a face lift Jacob ??? ???
jaco
Post by jaco » Sat Jul 12, 2008 6:29 am
I am bone idle lazy ...................
So will just fit the bit to the router in the table, and a few passes later have a chamfer 1000 times better than if i tried by hand.
8-) 8-) 8-)
President of the Windhoek Lager Can Collectors Guild
Post by jfc » Sat Jul 12, 2008 6:59 am
Need some Wenge Paul ? I still have about half a tree left 8-)
Wenge and maple with a stainless steel screw for fine adjustment , brass knobs are old hat !
jaco
Post by jaco » Sat Jul 12, 2008 9:19 am
Hi Steve,
Nice piece Paul! 8-) 8-)
Presume you WILL be posting some drawings and an ABC4TT guide on building it???
jay
Post by jay » Sat Jul 12, 2008 9:33 am
jaco wrote:I am bone idle lazy ...................
8-) 8-) 8-)
Each to their own and all that; but how is what you describe easier than going swish swish swish with a block plane? It's seriously not hard: Step 1 - look at plane, turn knob for deeper cut if needed. Step 2 - Suit up with ear defenders, eye protection and switch on dust filters and particle extraction Step 3 - hold plane in hand. Step 4 - swish, swish, swish. Also, I am interested in how you measure and quantify chamfer quality.
Post by thatsnotafestool » Sat Jul 12, 2008 10:42 am
jay wrote:
jaco wrote:
Sat Jul 12, 2008 7:29 am
......... Also, I am interested in how you measure and quantify chamfer quality.
Number of posts in a thread? ;D
Post by mrgrimsdale » Sun Jul 13, 2008 8:16 am
paulchapman wrote:Have you had a face lift Jacob ??? ???
;D Felt like a change. Stitches out next week. You should see what they've done to the rest of my body :o :o
Jacob
Post by jfc » Sun Jul 13, 2008 8:55 am
Awww gawd , first Pauline and now you ! :o ;D
Post by paulchapman » Sun Jul 13, 2008 10:09 am
mrgrimsdale wrote: You should see what they've done to the rest of my body :o :o
Blimey, I hope you're not going to post a picture of the other bits :o :o ;D
