Help Needed Frame Bed Repair!
MoridinUK
Post by MoridinUK »
Hello,
I've a frame bed that is quite important to my family! But its damaged and I've no idea if it how yo repair it. Over the years the kids have jumped on it too much and the wood is all crushed!
Any ideas on how to fix it up?
Re: Help Needed Frame Bed Repair!
Post by jfc »
Looks to me like the bolts where tightened a little too much and nothing to do with your kids .
Post by Doug »
Looks like the bolts are too long as the end of the thread is touching the back of the hole so the nuts & bolts would never have tightened up adequately.
Get a metal plate made to screw to the area of the damaged timber but still allow access to the nuts, weld the washers to the plate & shorten the bolts, they look more like worktop clamp bolts than bed bolts.
hercule
Post by hercule »
No amount of kids or fat people would do that much damage by jumping on the bed. Bolts been tightened up way too much
bourbon25
Post by bourbon25 »
Needs the split addressing as well Prise it apart slightly, force pva glue into the crack and set to dry. Then as has been suggested, Cut the bolts down and Big repair washers on the inside of the big hole
Post by Doug »
Hopefully after a year Moridin has sorted the problem
