Where a hole has been punched through the hull, my cunning plan is to remove with a router the damaged wood from the outside, first in a large area about A4 paper size, then the middle layer about A5, then the inner layer about A6. Then layup with new 2mm mahogany strips against a former on the inner side, layer by layer.
But... I have not used a router on a compound curvature before (:blush:)
I will be using a small 1/4 router, not the big Trend.
Suggestions and advice please on how to set up a jig or fence on an 'up and down' curve, and what bearing/cutter might be best.
thanks
I'll do the sensible thing and get some pics later
