need some advice re a sink fitting
katellwood
Postby katellwood » Sat Jan 21, 2012 10:27 am
Can anyone assist,
this sink was purchased some time ago in France and I now intend to fit it in a utility room
It is a very thick ceramic type material with what appears to be pop outs for left/right fitting tap fitting
to pop out the pop out do i just tap it with a hammer and if so from what side, and in anyones experience will it pop out clean
thanks in anticipation
mtr1
Re: need some advice re a sink fitting
Postby mtr1 » Sat Jan 21, 2012 10:44 am
I have done two like this, drill a small hole in the centre of the plug from the top, then get a punch and work from the centre out again from the top.......be very careful and only take out what you need to get the tap in. I take no responsibility if you fcuk it up ;)
All the best
www.markrhodesfurniture.co.uk
katellwood
Postby katellwood » Sat Jan 21, 2012 11:11 am
Is it easy to drill?
Postby modernist » Sat Jan 21, 2012 12:34 pm
mtr1 wrote:I have done two like this, drill a small hole in the centre of the plug from the top, then get a punch and work from the centre out again from the top.......be very careful and only take out what you need to get the tap in. I take no responsibility if you fcuk it up ;)
+1 but it is a terrifying process.
DavidO
Site Admin
Postby DavidO » Sat Jan 21, 2012 12:45 pm
I hate those and use a Tungsten Carbide Grit Holesaw.
Postby promhandicam » Sat Jan 21, 2012 5:22 pm
I've only fitted one, when we were in Cameroon, and I managed to get a crack right the way across the bowl and ruin it - never again.
