Quick wedge cutting on doors??
Louis1984
Postby Louis1984 » Thu Feb 04, 2016 8:10 am
Who has the best/quickest method for cutting the angles for wedges either side of the mortice? It's so laborious doing it by hand! A few hardwood doors and there's an hour gone on something I've always felt is made too difficult.
I once set up to do it on the morticer using roller stands at different heights. That was pretty effective and quick. Difficult on full length door styles though. A jig for the domino 700? Thai bird? Who knows. Love to here any tips
Re: Quick wedge cutting on doors??
Postby tusses » Thu Feb 04, 2016 12:22 pm
I've not tried it, but what about a power file ?
Louis1984
Postby Louis1984 » Thu Feb 04, 2016 12:26 pm
interesting..... I've just looked it up. great idea, not sure if the power would be sufficient enough though
Postby tusses » Thu Feb 04, 2016 12:26 pm
is it standard pratice to wedge like that ? you are describing what I know as a fox wedge, but not hidden.
I thought you just saw some kerfs into the tenon and the wedges tighten everything up ?
Postby tusses » Thu Feb 04, 2016 12:42 pm
Louis1984 wrote:interesting..... I've just looked it up. great idea, not sure if the power would be sufficient enough though
With a coarse belt, they remove wood quickly.
Louis1984
Postby Louis1984 » Thu Feb 04, 2016 9:28 pm
tusses wrote:is it standard pratice to wedge like that ? you are describing what I know as a fox wedge, but not hidden.
It's standard practise. I Mark 8mm either side of my mortice then with a chisel angle them inwards. The wedges can then drive the component forwards and tightening up
Postby Jonathan » Thu Feb 04, 2016 9:37 pm
"tilting morticer" should do the trick......
or a poor man's tilting mortice, a long wedge on the bed......
Postby Jonathan » Thu Feb 04, 2016 9:40 pm
or a poor man's tilting morticer, a long wedge on the bed.
That's what I used to do, all be it 20 odd year's ago ...
