Stanley No6 and No 7 Planes
ljdyork
Postby ljdyork » Thu Dec 19, 2013 11:01 am
Does anyone know whether a No 6 Frog/Blades/Woodwork will fit on a no 7 Stanley base?
I have a No 6 which I have had and loved for many years but the base has developed a split (where a repair existed from when I got plane 40 odd yrs ago.).
If a no 7 will take all the bits then it widens my chance of getting a base. I already have a couple of 5's and a 5/12 so only use it now for long joins - and if I have a lot of hard stuff to do as I like the extra weight kicking it through.
Thanks les
Re: Stanley No6 and No 7 Planes
Postby karl » Thu Dec 19, 2013 7:40 pm
I'm pretty sure it will - 2 3/8" blade is common to both planes.
ljdyork
Postby ljdyork » Fri Dec 20, 2013 9:43 pm
Thanks Karl.... there's a Stanley 7 base for sale..... I'll give it a go as I think a repair to my base will be not very practical
cheers les
Vic.P
Postby Vic.P » Sat Jan 04, 2014 10:11 am
Hi Les,
As Karl says, your parts "should" fit the No 7 body but just be aware that the frog and frog reciever castings have undergone a number of changes over the years so it's probably best to identify the type number of your old plane before buying a replacement body.
Have a look here: http://www.tooltrip.com/tooltrip9/stanl ... -types.htm
This chart outlines the changes to castings etc so you should be able to work out the type number of yours.
Best of luck.
Vic.
Return to “Hand Tools”
