I've had an urge to build something for many years now and have finally bought myself a few handtool to learn with (tenon saw, chisel set w honing guide and stone, #4 plane, com sq, soft hammer, mortise gauge, 2 clamps and a table-top vice not to mention some wood).
I'm hoping to make new bed side set of draws. My plan is to laminate a few pieces of wood for the sides and tops with with either dove tail, rabbit or tenon joints and have the draws sliding via dado runners.
I've decided on pine to start with (a rough prototype and cheaper) and once I have successfully done so I plan on making the final out of walnut (once I can make a clean cut that is)
I've sat down, watched a few YouTube videos for guides on sharpening my out of the box chisels and plane blade which seemed to go well. Chopped a length of wiggly wood to practise on.
The problems Im having at the moment is everything is sticking and jumping. When I saw, I can't get a clean cut and when I've tried planing I end up frustrated as the plane hops and digs in. I've tried going light handed with nothing and I've tried putting my whole body weight behind it which ends up pushing/tilting the wood out of the vice.
As I said earlier I know things are going to get easier with practice and time but at the moment the simplest of tasks are putting me off from seeing it through. I currently don't want to have another go as I fear I'll just ruin the wood I have and then not bother to get any more, and then add the tools to the "failed" corner of the attic to collect dust.
Any advice or thoughts are welcome, thanks in advance.
Ray
