Courier/delivery for wide belt sander..
timbly
Postby timbly » Wed Jan 06, 2016 3:29 pm
Hi
Need to move a wide belt sander (1100kg, 2m tall, 1.65m wide, 1.8m depth ) from Essex to West Devon. We’ve been quoted £600 + Vat and was wondering if anyone could recommend a delivery service (hopefully a bit cheaper..).
Tim
rhrwilliams
Re: Courier/delivery for wide belt sander..
Postby rhrwilliams » Wed Jan 06, 2016 6:52 pm
I have had stuff delivered on pallets a few times that are slightly bigger then they are supposed to be and its always been ok......Its not like they weight the pallets !
National Pallets do a "FULL OVERSIZE PALLET" for £116.00 ish (depending on location) - specs below - you would need to lay it on its side if its 2m tall....you would also need to tell a very small porky pie about the weight. I won't tell anyone ;)
MAX HEIGHT:220CM / 86.61"
MAX LENGTH:240CM / 94.48"
MAX WIDTH:100CM / 39.37"
MAX WEIGHT:1000KGS / 2204LBS
rhrwilliams
Postby rhrwilliams » Wed Jan 06, 2016 6:54 pm
Sorry Ive just seen you are slightly over on the dimensions too, maybe phone them and see if they will take it on an oversized pallet.
timbly
Postby timbly » Sat Jan 09, 2016 3:26 pm
Thanks for your suggestion rhwilliams. After a lot of ringing around found a company who've offered to do it for a little over £300. Hopefully all will go well and by this time next week we'll have a wide belt sander positioned in our workshop..
