At W14 I remember seeing some blast gates on duct work, they you could operate with a wire dangling down. pull one side to open, pull the other side to shut.
I can't find them anywhere, and that is perhaps to do with the fact I have no idea what they are called.
I need 2 no 200mm fittings.
Can anyone help me, I may even need to get them made.
Thanks in advance.......
Blast gates help.
Blast gates help.
Re: Blast gates help.
Could you do something with blast gates with a 90 degree rotating blade inside, rather than the slidey door type? With a dangly piece of wood attached to turn, rather than a wire to pull?
Unless you want to go really posh and have pneumatically operated.......I'd have the stick method and spent the rest on my tractor
have a look here
http://www.jacob-pipesystems.com/products/
So anyway couldn't find one, but found an idea on the internet of a home made one, so 10 minutes on the computer, 5 minutes on the CNC, 5 minutes assembly and voila.
Not tested it yet, but basically this will connect vertically to 200mm ductwork above the machine. It will have some gripple wire attached to the 2 outer bolts on the moving parts, pull one to open, pull the other to shut.
Blast gate in use.
NICE.....
I use pull cords for the on/off on the extractor, all that stretching up keeps my back moving and I don't need to go to yoga anymore.
That's better than mine, although I did rip off from someone else
Such an improvement over the leaky eliptical gate supplied with the ducting order.. and considerably cheaper!
