bit of wax on oak?
Smeeagain
bit of wax on oak?
Postby Smeeagain » Tue Jun 23, 2015 11:51 am
So I'm not so much of a woodworker, but I tinker.
I've made a drinks coaster. So yes its just a square of wood 20mm thick, but I've hand decorated with a pyrography pen and I'm happy with the result. Some self adhesive on the base and it looks quite smart.
I'm thinking as a coaster it needs (or doesn't?) some kind of protection? I was goign to apply some wax over the top surface. So my questions are
Is that the right thing to do (to protect from rings from cusp etc) - maybe it wont make any difference?
If I apply the wax do I then simply buff by hand or do I use a buffing wheel on a bench grinder that I have ?
thanks,
Smee
Re: bit of wax on oak?
Postby nickw » Tue Jun 23, 2015 4:35 pm
Wax is not a durable finish, and not suitable for use under e.g. hot cups. Hardwax oil (e.g. Osmo Polyx) would be a better bet. Do read the instructions about disposal of rags, and do apply 2-3 coats as thinly as you possibly can with a rag, allowing to dry between coats, and light sanding with p180 or finer, between coats.
Postby nickw » Tue Jun 23, 2015 5:15 pm
Smeeagain
Postby Smeeagain » Wed Jun 24, 2015 9:05 am
thank you.
When I google Osmo polyx hardwax oil I get a lot of Osmo variants - is the difference simply the finish (ie matt, satin etc) - I guess what Im asking is is there a right or wrong one to buy (aside of matt satin etc)
https://www.google.co.uk/webhp?sourceid ... ardwax+oil
On oak its going to raise the grain isnt it - hence the rubbing back?
Lastly you say apply as thin as possible - should I be thinnning it with something?
Smee
Postby promhandicam » Wed Jun 24, 2015 9:34 am
Just go for Osmo 3032 original or 3232 quick drying, apply with a brush and then aftera mminute or two wipe off with paper towel until surface is touch dry. When fully dry light rub down to denib and repeat.
Smeeagain
Postby Smeeagain » Wed Jun 24, 2015 11:05 am
thats great, thanks
Smee
Smeeagain
Postby Smeeagain » Fri Jun 26, 2015 9:46 am
ok so this worked a treat, thanks. Looks nice
Can I apply wax on top if I want to - just a personal thing but I like the wax finish
Smee
Postby promhandicam » Sat Jun 27, 2015 7:58 pm
Yes you can use wax on top of Osmo.
Smeeagain
Postby Smeeagain » Sun Jun 28, 2015 9:11 pm
Thanks. I went ahead and tried and am quite happy with it
Smee
