Paintable silicone sealant
Louis1984
Postby Louis1984 » Sun Jul 19, 2015 5:47 pm
Can anyone recommend an external silicone which is paintable?
MrYorke
Re: Paintable silicone sealant
Postby MrYorke » Mon Jul 20, 2015 6:06 am
Not silicon but an exterior sealant. Acrylic.
http://m.screwfix.com/p/no-nonsense-ext ... tered=true
Postby jake » Mon Jul 20, 2015 8:52 pm
MS polymer
Postby promhandicam » Mon Jul 20, 2015 10:09 pm
jake wrote:MS polymer
Do you have shares in a company that makes MS Polymer adhesives Jake :lol: :lol: :lol:
Postby jake » Wed Jul 22, 2015 9:24 pm
No it's just f**king ace (apart from some bathroom specific crap I bought which has gone horribly yellow, at least I could paint it I suppose) and so much better than silicone.
Postby Roger-M » Fri Aug 07, 2015 2:32 pm
Since I discovered CT1 I haven't used anything else. Brilliant stuff. Sticks to any surface, even if wet, and overpaintable, and doesn't shrink or go brittle with age. Not cheap at around £10 per tube, but well worth it.
Louis1984
Postby Louis1984 » Thu Aug 13, 2015 10:56 pm
Been using Geocel decorators calk which can be used externally as well. Good stuff. Cheap as chips!
hungover
Postby hungover » Sat Aug 22, 2015 8:56 am
Roger-M wrote:Since I discovered CT1 I haven't used anything else. Brilliant stuff. Sticks to any surface, even if wet, and overpaintable, and doesn't shrink or go brittle with age. Not cheap at around £10 per tube, but well worth it.
Unfortunately CT1 yellows.
Toolstation sell the everbuild puraflex 40 for £4.04. TBH I don't know if that yellows or not. Additionally I have only ever seen it in white.
BTW, both products need to be primed with water based paint first, otherwise the oilbased paint will remain tacky for days.
