Renovation
Renovation
Postby Tomyjoiner » Tue Dec 01, 2015 8:37 pm
These are a few doors I've recently done for a renovation. I went back the other day to touch up some units i also did. So i grabbed some pics (iPhone so not the best)
these first 2 are in idigbo and are for the walled garden. I usually use sapele but i thought id give idigbo a go. Nice an light as the big door is over 1m
the back door is sapele with 25mm insulation inbetween
these were just internal french doors to match existing. all were just supplied glazed and primed.
Re: Renovation
Postby Tomyjoiner » Tue Dec 01, 2015 10:09 pm
cupboard with sliding doors
small office
2350h x 4.2l a bit awkward moving around the workshop
poplar top
Doors have push catches on. The builder was supposed to put on 9" ogee skirts but instead the joiners used 5"?? so it looks bloody daft.
Re: Renovation
Postby Tomyjoiner » Tue Dec 01, 2015 10:17 pm
left end is for 2 boilers and round to the right is for washer & dryer.
Boot room.
The tops were added on after for more storage.
Re: Renovation
Postby Tomyjoiner » Tue Dec 01, 2015 10:25 pm
bedroom Vanity
Bedroom vanity
Wardrobe
Their were 4 more of these all different sizes an a 3m long one in master bed with etched glass doors but forgot to get a pick of that one.
Re: Renovation
Postby Leveller2911 » Thu Dec 03, 2015 5:10 pm
Nice work thereTJ......
I've only used Idigbo once and it was ok, funny grain as its a bit like Sapele as it can go both ways.That Blue entrance door looks very wide or is it just the camera angle?.
I've just finished making and fitting some some bowed (curved) sash windows which were fun to make but squeeky bum time as I was a tad worried they wouldn't fit..
Re: Renovation
Postby Tomyjoiner » Fri Dec 04, 2015 9:26 pm
Thanks. The door was just under 1100 wide but was only 1900 heigh so makes it look even wider, an yes very similar only idigbo is half the weight. Any pics of the sashes, bet they were good to do! I did a bow window in the summer. Tried getting the picture up but says file too large. i can only do the drag an drop as i can never get the flickr thing to work :oops:
Re: Renovation
Postby thatsnotafestool » Fri Dec 04, 2015 10:09 pm
Do you mean insulation between two panels in that back door?
Re: Renovation
Postby Tomyjoiner » Sat Dec 05, 2015 11:18 am
Yes, the lining with c*ck bead was 16 mm either side and i was going to use some 25mm kingpin in-between but i had a bit of tri iso left on a roll so i used that instead so its really got 100mm insulation! so with the 25mm tri iso it made the door finish at 57mm. I tried to get 20mm insulation but no one had it in at the time. In hind sight i should have done it in idigbo as it was bloody heavy.
Re: Renovation
Postby thatsnotafestool » Sat Dec 05, 2015 10:04 pm
I was just wondering about the gap at the bottom having gone to all that trouble !!
Re: Renovation
Postby Tomyjoiner » Sun Dec 06, 2015 12:19 am
Oh rite, sorry i was talking bout the sapele door with glazing. That 8 panel door is outside, its the entrance in the walled garden to the lane.
